September 28, 2026, 02:50:34 pm
All Things Mk5
Mk5 General Area
Xenon Replacement covers
Topic: Xenon Replacement covers (Read 1837 times)
edition_30
Always Involved
-Given: 5
-Receive: 3
March 26, 2011, 02:01:55 pm »
Is it possible to replace the plastic protection covers on a set of zennons as I notice that there are metal clips holding the cover in place?
h4rdy
Re: Xenon Replacement covers
Reply #1 on:
March 26, 2011, 02:04:38 pm »
I am slightly unsure but I don't believe so as when I went for a replacement unit it looked to be complete.
Also when I tried to take my damaged one apart it was not easy.
Its a shame my wife made me throw it away or you could have had it!
edition_30
Always Involved
-Given: 5
-Receive: 3
Reply #2 on:
March 26, 2011, 02:41:10 pm »
Thanks for the reply mate
I do have the standard halogen units on my car currently, do you think a swap would be possible?
h4rdy
Reply #3 on:
March 26, 2011, 05:26:05 pm »
Sorry no idea.
mortygttdi
Just look at my post count
-Given: 44
-Receive: 146
Reply #4 on:
March 26, 2011, 06:17:40 pm »
You could swap the covers from an halogen but you would need to make sure the markings on the covers are the same on both? Other wise your going to have different light patterns
Darren
edition_30
Always Involved
-Given: 5
-Receive: 3
Reply #5 on:
March 26, 2011, 07:52:27 pm »
Thanks for the reply Darren. The halogens are currently on my car from factory so the markings should be the same no?
Also is it just a case of removing the clips & the covers come off?
mortygttdi
-Given: 44
-Receive: 146
Reply #6 on:
March 26, 2011, 08:15:37 pm »
Bit more envolved than that mate, you need to heat the light cover around the edges then tease it off then replace it and again heat the edges to seal it back up,
The clips are just there to make the seals stick from factory.
Darren
edition_30
Always Involved
-Given: 5
-Receive: 3
Reply #7 on:
March 26, 2011, 08:51:39 pm »
Hairdryer should do the trick yea? Do you think any extra adhesive would be needed as I would want to make sure the seals keep the water out
apollo13
-Given: 2
-Receive: 47
Reply #8 on:
March 26, 2011, 08:54:47 pm »
I know the mk4 boys put them in the oven for 5 mins or so the soften the sealant and then slowly ease them apart using a hairdryer/heat gun on low if needed.
Most reheat to reseal but I know some used tiger seal to real if needed.
All Things Mk5
Mk5 General Area
