Author Topic: Car stutters when I start it- advice please  (Read 1775 times)
Offline Homer
« on: April 18, 2011, 01:06:55 pm »
Hi, this is something which the car does regularly usually when the engine is cold. When I turn the key it stutters like it's not going to start but at the last second it fires into life. Any thoughts what this could be? And would it be covered under warranty? Thanks
Offline Gtiain
Re: Car stutters when I start it- advice please
« Reply #1 on: April 18, 2011, 01:10:42 pm »
I believe this is quite common and nothing to worry about.
Offline bacillus
  • -Receive: 453
« Reply #2 on: April 18, 2011, 01:16:03 pm »
How old is your battery as this could be a first sign that its not holding charge.
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #3 on: April 18, 2011, 01:46:42 pm »
This is a fairly well documented issue with TFSI engine it normally takes a longer hold of the ignition key for it to burst into life.  It would be worth your while checking the battery as Bacillus says and other common issues that could stop a car firing up.  It has however been discussed several times that they can take longer than some engines to burst into life.
Offline em2evol
  • Let's Motorvate!
« Reply #4 on: April 19, 2011, 09:20:20 am »
Yep, I get this all the time and it's never been an issue   :happy2:
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #5 on: April 19, 2011, 09:27:11 am »
My ED 30 does it sometimes,only just 3 years old.Had battery tested & it's fine so don't worry about it. :happy2:
