Author Topic: IPOD doc won't play ipod....... Set up help required !  (Read 7625 times)
Offline Fastmonkey
« on: April 19, 2011, 01:55:13 pm »
Got my new ipod doc in the post today, got some auto leads removeal tools, removed the USB dock and installed the ipod. Looks like the plastic ipod holder thing is for a nano so removed that and just wedged my ipod in for a trial. But I get nothing.......... No charge  no music........
Is there work to do on the MFD2 to set it up or is my ipod not compatible. According to Apples website it is an IPOD Classic 80gb from 2007 to 2009 ?
MK5 R32 DSG Build thread   -  http://www.mk5golfgti.co.uk/forum/index.php/topic,23512.15.html
MK2 VR6 Vortech Charged
Offline Richn83
  • -Given: 49
  • -Receive: 86
Re: IPOD doc won't play ipod....... Set up help required !
« Reply #1 on: April 19, 2011, 02:00:13 pm »
have you got the ipod in the right way round?  the holders are designed to ensure they go in the right way.
I'm also not sure if that gen ipod was firewire chargin compatible or not thats about the time they switched, the ipod dock itself doesnt support usb chargin like the new ones so make sure your ipod has charge.
Offline Fastmonkey
« Reply #2 on: April 19, 2011, 03:14:37 pm »
Prett sure the ipod is in the right way round as per this pic ?
Also ipod is fully charged and the AUX setting is set to Audio ?
When I go back to the aux screen it shows all the play fast forward icons but nothing happens ?
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #3 on: April 19, 2011, 03:27:38 pm »
yeah I would have to agree thats in the right way!  :signLOL:
Not used the changer with the MFD before only RNS510, does pressing CD twice give you different options?  And I assume the USB one worked before removal  :innocent:
Offline Fastmonkey
« Reply #4 on: April 19, 2011, 03:36:00 pm »
USB worked fine before ......... :-(
Offline alexperkins
  • -Receive: 99
« Reply #5 on: April 19, 2011, 03:43:16 pm »
Ipod is right way around
When you plug it in, does a VW logo show on the screen?
iPod doesnt use AUX in. It uses the CD changer input, so you need to press the CD button at the bottom of the unit
That iPod will work as thats what I used on my Ipod dock before upgrading to MDI
Offline Fastmonkey
« Reply #6 on: April 19, 2011, 06:00:57 pm »
Thanks for all the help so far, I don't get a VW logo on the ipod at all ?
Offline alexperkins
  • -Receive: 99
« Reply #7 on: April 19, 2011, 06:35:32 pm »
Then its not working
Did you plug the loom into the bottom of the dock securely?
Its possible you may need to change the cable to the CD changer variant.
Offline Fastmonkey
« Reply #8 on: April 19, 2011, 07:37:08 pm »
Yep and took it all out to double check it and it's clipped in perfectly. Is it worth trying another ipod or something ? I thought they were all interchangeable ?
Any info on the cable, cost, fitting etc........... blimey it's never easy is it :-(
Offline alexperkins
  • -Receive: 99
« Reply #9 on: April 19, 2011, 07:46:45 pm »
You could try another iPod, but it could be either a faulty dock or it wont work with that lead
Offline Fastmonkey
« Reply #10 on: April 19, 2011, 09:30:39 pm »
Ok thanks I'll borrow another ipod to try first.
If it is the lead, any ideas what I would need to get and is it a major job to fit ?
Offline alexperkins
  • -Receive: 99
« Reply #11 on: April 19, 2011, 10:21:17 pm »
Aye I can sort the part number and yes reasonably easy
Offline Fastmonkey
« Reply #12 on: April 19, 2011, 11:00:32 pm »
Oh ok well that leaves me feeling a bit happier that it might work out then........ Thanks for your help, let me know if you can find a part number then or point me in the right direction.
Offline alexperkins
  • -Receive: 99
« Reply #13 on: April 19, 2011, 11:29:41 pm »
Are you sure the dock works?
Offline Fastmonkey
« Reply #14 on: April 20, 2011, 12:10:00 pm »
I contacted the guy who sold it and he said it was working fine in his car before it came to me so not sure where I can go from there ?
