Author Topic: Needle Sweep  (Read 8642 times)
Offline johnhol78
Needle Sweep
« on: April 20, 2011, 02:33:01 pm »
IS it possible to have the needle sweep on a standard GTi?
I read the Scirocco does it but is it an option that can be turned on in VCDS?
Re: Needle Sweep
« Reply #1 on: April 20, 2011, 02:38:28 pm »
Not on the Mk5.
Offline johnhol78
Re: Needle Sweep
« Reply #2 on: April 20, 2011, 02:41:24 pm »
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
Re: Needle Sweep
« Reply #3 on: April 20, 2011, 04:00:17 pm »
Unless of course you want to replace the Dash & CECM. Bit of an expensive way for a gimmick though :laugh:
Offline johnhol78
Re: Needle Sweep
« Reply #4 on: April 27, 2011, 10:00:10 pm »
Think I'll pass..... :wink:
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
Re: Needle Sweep
« Reply #5 on: April 27, 2011, 11:26:28 pm »
Must admit it does look good but what is the point of it ????.
Re: Needle Sweep
« Reply #6 on: April 27, 2011, 11:28:08 pm »
Cluster test... no point in it really!
I know someone who has home made and developed an add on module for the mk4 golf which will make the clocks sweep on ignition!  :signLOL:
Offline apollo13
  • -Receive: 47
Re: Needle Sweep
« Reply #7 on: April 29, 2011, 12:11:41 am »
Imagewerx?
Re: Needle Sweep
« Reply #8 on: April 29, 2011, 12:19:40 am »
Offline apollo13
  • -Receive: 47
Re: Needle Sweep
« Reply #9 on: April 29, 2011, 12:28:52 am »
Top work getting that sorted, a square wave I believe.
If only I had the time......
