Author Topic: Parking sensors  (Read 1885 times)
Offline N44LED
Parking sensors
« on: April 27, 2011, 12:06:59 am »
Hi guys
I have rear parking sensors on my gti but the only problem is that they dont work,  when it is put in reverse it has a constant beep for about 2-3 seconds then goes off thinking its ready but it does not sense any thing has any body had this problem as it is bugging me thank you
thanks Aled  :smiley:
Offline no golf clubs at all
Re: Parking sensors
« Reply #1 on: April 27, 2011, 06:37:33 am »
Have a visual inspection of the sensors on your rear bumper. 2 of mine need replacing as they have corroded under the paint. I removed the paint gently it stopped the continuous tone in reverse, worked for a while but still get variable results.
They are not cheap to replace. Mine is booked in 9th May.
Offline StuF
  • -Given: 31
  • -Receive: 38
Re: Parking sensors
« Reply #2 on: April 27, 2011, 10:27:01 am »
I have the aftermarket parking dynamics kit fitted to my car as it didnt have any originally.  :sad1:
They dont have actual sensors just a metallic strip that fits inside your rear bumper.  :laugh:
Mine work brilliantly. Might be a cheaper option than the VW one??  :evilgrin:
Im saving up now for the retrofitted MK6 pop out camera! But its expensive at the mo!
Offline N44LED
Re: Parking sensors
« Reply #3 on: April 28, 2011, 07:39:50 am »
hi thanks for the help
they are oem fitted.  is there any way of testing them
One of the sensors has a little black mark on one side looks like dirt or was just missed when sprayed will try and clean it up.
Also would plugging it in to the laptop find the problem or not,  not to sure what software you use for the mk5  as vag com is for the mk4`s
Thanks aled
Re: Parking sensors
« Reply #4 on: April 28, 2011, 08:13:36 am »
Worthwhile giving a gentle clean there could just be debris in there as above two of mine are badly corroded down the bottom lip. There's no option but to swap out (apart from go into vagcom and turn down the volume).
