September 02, 2026, 10:57:33 am
All Things Mk5
Sat Nav and Car Audio
Quick RNS510 question
Topic: Quick RNS510 question (Read 2090 times)
Rich_gti
Taking part
-Given: 0
-Receive: 0
April 29, 2011, 09:21:51 am »
Seeing that the mother in law has turned up (
) to watch the wedding I thought it was about time I looked at installing my RNS 510.
My question is this:
I have a 'K' gateway that I also need to install but do I need to get it coded or is it a simple plug in?
stealthwolf
Just look at my post count
-Given: 306
-Receive: 292
ED30 No.1412
Re: Quick RNS510 question
Reply #1 on:
April 29, 2011, 09:24:35 am »
You won't have a battery drain issue, so simple plug and play. The unit will work okay without telling the car it's there, but realistically you need to tell it you have the satnav install. You'll need access to VCDS for this.
The
GTI
isn't just a machine. It's very much a living, breathing thing.
alexperkins
-Given: 7
-Receive: 99
Reply #2 on:
April 29, 2011, 09:34:09 am »
There is a possibility that you will have the battery drain issue on a K gateway - it depends what software version and the date stamped on it is
Rich_gti
Taking part
-Given: 0
-Receive: 0
Reply #3 on:
April 29, 2011, 09:48:38 am »
Thanks for the info.
So in theory I can install the unit (version C) today, gain access to VCDS at a later date, and be out of the house and miss the wedding & the in-law?
Happy days
alexperkins
-Given: 7
-Receive: 99
Reply #4 on:
April 29, 2011, 09:50:38 am »
If you are changing the gateway, youll need access to VCDS today to code the gateway to work in the car, else it wont work at all and youll have big problems
Where are you based Rich?
Rich_gti
Taking part
-Given: 0
-Receive: 0
Reply #5 on:
April 29, 2011, 09:58:31 am »
Ah ok I see what you mean.
I'm based in Birmingham.
If that's the case, do I need to have access to VCDS before if start swopping things around or would I be able to fit it, then drive somewhere to get it coded?
Apologies for the questions but as you can kinda guess, this is a tad out of my comfort zone
alexperkins
-Given: 7
-Receive: 99
Reply #6 on:
April 29, 2011, 09:59:43 am »
Youd need it coded before you restart the car again!
Im actually in birmingham next weekend (Fri Eve/Sat/Sun) if thats any use to you
Rich_gti
Taking part
-Given: 0
-Receive: 0
Reply #7 on:
April 29, 2011, 10:10:30 am »
Sweet!
Thanks for the offer
I'll double check what I'm working (oh the joys of retail) and drop you a quick pm.
Rich
alexperkins
-Given: 7
-Receive: 99
Reply #8 on:
April 29, 2011, 10:11:57 am »
No worries. Just let me know
All Things Mk5
