Author Topic: boot popper on fob  (Read 8926 times)
Offline N44LED
boot popper on fob
« on: May 11, 2011, 12:24:46 am »
hi guys just looking at some vid`s of the mk5 boot popin on the key fob but when i press the button on mine nothing happens is this a common fault/has any one had this problem if not any one got any help as now seen the vids of it in action i now want it to work on mine
Thank`s aled
Re: boot popper on fob
« Reply #1 on: May 11, 2011, 01:03:25 am »
You have to change the boot struts, pins and stoppers. You'll also need the boot pop enabled with vcds!
Offline N44LED
« Reply #2 on: May 11, 2011, 10:04:58 am »
arr right not sure if it hasnt worked at all would it normally just pop open and remain a jar.  where can you get the gear to make it happen.
But my main consern is that the button on the fob doesnt do anything is this just something that is there but not activated or a fault
Aled
« Reply #3 on: May 11, 2011, 10:09:26 am »
The boot button should open just the boot  :happy2:
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #4 on: May 11, 2011, 10:10:58 am »
you have to press and hold the boot button to make it operate, a single press wont do anything.
« Reply #5 on: May 11, 2011, 10:11:14 am »
To do the pop you need the following parts!
2 x 6Y0 827 550 C (Skoda Fabia gas springs)
2 x 1K8 827 761 C (Scirocco bumpers)
2 x 1J6 827 439 A (Seat Leon ball pins)
Offline N44LED
« Reply #6 on: May 11, 2011, 10:39:26 am »
All from the steelers any idea on price for them mate
« Reply #7 on: May 11, 2011, 10:41:22 am »
Cant remember of the top of my head... but about 45-50 in total!
Offline N44LED
« Reply #8 on: May 11, 2011, 11:13:09 am »
sound ta mate.
Just been out to it beeing a bit dim really :signLOL:, if i hold it it only just unlocks the boot but soon after i close it locks so it does work but if i put all that gear on it will it pop open or have you got to get a diffrent lock that flicks open
Aled
Offline SRC
  • -Receive: 27
« Reply #9 on: May 11, 2011, 11:18:17 am »
In case it's not clear, the standard set up means you have to press and hold the boot remote for about a second.  Then you can open the boot (using the handle).  The rest of the doors remain locked.  Then, when you shut the bootlid, it automatically locks again.  It's handy when you've taken something big or heavy out, bu it's not as flash as a popper mod.
Shadow blue DSG 5 door with leather, sunroof, 18" Monzas, MFSW.
Full list of mods:  Seat inserts and a VW bottle opener.  Each worth 20bhp.
Offline N44LED
« Reply #10 on: May 11, 2011, 11:24:29 am »
ye that is correct mate, just found that out only had the car just on a month now but thought i found everything out about it and the person before didn really know  :stupid: considering they paid 28,000 for it new  :scared:.
but ye i take it now that the boot poppin thing is a retro fit or did vw acctually do this on some cars as i am interested in havin it on mine as it would be handy plus look kinda cool but depending on the cost and effort to make it happen.
Aled
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #11 on: May 11, 2011, 11:24:41 am »
you need to fit all the bits Rich listed and then change the coding on the lock mechanism, it has two settings one to unlock but stay caught needing final release by the handle, the second allows full release so with the beefier struts the tailgate will open fully.
It was never standard in the UK as far as I know but the computer and mechanism is there as its a feature on othere VW cars and booted cars.
« Last Edit: May 11, 2011, 11:26:12 am by Richn83 »
Offline N44LED
« Reply #12 on: May 11, 2011, 11:30:28 am »
arr right so the lock only needs programing then if thats my understanding (correct if wrong ta) and just fit the parts as rich said.
Next question how and who can do the programeing  :happy2:
Aled
« Reply #13 on: May 11, 2011, 05:26:11 pm »
Anybody with VCDS. Look at the register.
Offline N44LED
« Reply #14 on: May 14, 2011, 11:04:08 pm »
Thanks for the help guys think am gunna get on to this and make it my first mod  :happy2:
