Author Topic: Replacing RCD300  (Read 2250 times)
Offline jkerry2782
Replacing RCD300
« on: May 16, 2011, 08:34:18 pm »
Hi have just brought a golf gti 2005 with an RCD300 and ipod in the arm rest, if i upgrade to a RCD310 exactly what parts do i need to complete the job and if possible can i have links to the parts please.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Replacing RCD300
« Reply #1 on: May 16, 2011, 08:38:38 pm »
Hi
If you upgrade to the RCD310 or newer type vw radios you will need a new CAN Gateway
do you have Vag-com?
if not what is your location?
Cluster and Key coding
Location Great Yarmouth
Offline jkerry2782
« Reply #2 on: May 16, 2011, 08:40:54 pm »
hi i am near norwich and have no idea whihc can gateway i need and are they just plug and go, it been while since i did any stereo changing.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: May 16, 2011, 08:45:16 pm »
Hi
I'm in Great Yarmouth and have Vag-com and do retrofits. I changed someones gateway only yesterday. I also am able to get hold of some for less than what the dealer charges.
Ed
Offline jkerry2782
« Reply #4 on: May 16, 2011, 08:47:51 pm »
Hi so how much does it cost for you to change the gateway so the car will work with rcd 310 and will the ipod system work with as well.
Offline janus909GTI
« Reply #5 on: May 18, 2011, 05:20:03 pm »
Ed, what is Vag Com???
I'm looking to get the RNS510, also have a 2005 gti, what do i need to do?
Plus, do you have any of these in stock?
hugh jass
« Reply #6 on: May 18, 2011, 05:38:44 pm »
