Author Topic: Error Codes  (Read 3349 times)
Offline liver
Error Codes
« on: May 19, 2011, 09:28:32 pm »
i scanned my golf tonight for fault codes, heres what i found, wonder if anyone can help me rectify them, or state what could be the problem as they mean pretty much nothing to me
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 B    HW: 1T0 035 680 B
   Component: RNS-MID       H03 0900
   Revision: AB001001    Serial number: --------------
   Coding: 040004000400000200
   Shop #: WSC 00066 000 00000
   ASAM Dataset: ------------------------- ------
   VCID: 2D556C16CD81
2 Faults Found:
00856 - Radio Antenna
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100111
                    Fault Priority: 5
                    Fault Frequency: 10
                    Reset counter: 66
                    Mileage: 88736 km
                    Time Indication: 0
01299 - Diagnostic Interface for Data Bus (J533)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 62
                    Mileage: 88739 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:32:33
thank you
Offline alexperkins
  • -Receive: 99
Re: Error Codes
« Reply #1 on: May 20, 2011, 12:05:48 am »
Are you using the proper VW antenna adapter if its retrofitted?
Offline liver
Re: Error Codes
« Reply #2 on: May 20, 2011, 08:53:48 am »
yeah i retrofitted using genuine vw parts for everything that was fitted
Offline alexperkins
  • -Receive: 99
Re: Error Codes
« Reply #3 on: May 20, 2011, 09:14:25 am »
that error might have occured from before the adapter was in place. what happens if you clear it?
Did you replace the gateway?
Offline liver
Re: Error Codes
« Reply #4 on: May 20, 2011, 09:16:08 am »
when i clear it they just come back on, cleared them numerous amounts of times now
i don't believe so, litrally just retrofitted nav and gps aerial, its a b version so i didnt get the battery drain
Offline alexperkins
  • -Receive: 99
Re: Error Codes
« Reply #5 on: May 20, 2011, 09:18:21 am »
Did you code in 37 - Navigation and check the Long Coding on the RNS to check it wasnt previously coded
Offline Richn83
  • -Given: 49
  • -Receive: 86
Re: Error Codes
« Reply #6 on: May 20, 2011, 09:48:41 am »
I have the:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 121
                    Mileage: 47667 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:38:13
Had it and some other eroor codes present since installing my RNS not been able to solve them but everything is working so I have ignored them, I am also running an old can gateway with modified firmware so I have put some of this down to that.
Offline alexperkins
  • -Receive: 99
Re: Error Codes
« Reply #7 on: May 20, 2011, 09:51:27 am »
Modified software can cause errors - It caused a CAN error on the RNS until I reflashed it up to 3970 when it went away
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
Re: Error Codes
« Reply #8 on: May 20, 2011, 10:00:24 am »
I had errors with RNS and my old gateway, if fitting a new gateway errors will most probably dissappear.
Over the top mod list ;o)
