September 27, 2026, 01:57:54 pm
All Things Mk5
Mk5 General Area
Canbus location 2007 GTi Ed30
Topic: Canbus location 2007 GTi Ed30 (Read 5294 times)
Peter85
Taking part
-Given: 0
-Receive: 0
May 21, 2011, 05:44:25 pm »
Hi Guys
i want to change my rcd300 for a rcd510, after reading up on the battery drain issue i thought id check my Canbus model.
I have a 56 (2007) edition 30 and followed the steps on the My-Gti website. I have removed the cover above the pedals but im pretty sure the canbus isnt there.
Does anyone know is the location is different on an edition 30?
Your help would be much appreciated!
Last Edit: May 21, 2011, 06:44:27 pm by Peter85
Eddie-NL
Trader - 2014
Just look at my post count
-Given: 0
-Receive: 298
My Ride:
Re: Canbus location 2007 GTi Ed30
Reply #1 on:
May 21, 2011, 06:01:17 pm »
could be here
http://www.r32oc.com/tutorials-guides/30166-canbus-gateway-location-removal.html
Genuine VCDS VAG-COM HEX-USB + Genuine Vag Commander + Genuine VAG Tacho + Genuine VAG CAN PRO + RNS Manager for Video in Motion and New Pin Code for RNS510
Cluster and Key coding
Location Great Yarmouth
alackofspeed
Always Involved
-Given: 6
-Receive: 24
Reply #2 on:
May 21, 2011, 07:27:45 pm »
Mine was in the location under the scuttle access hatch, but being lazy I was sure there would be an easier way.... so I had a look, saw the relay holder unclips, moved it aside, and stuck my hand through the gap to grab and remove the CAN gateway.
vRStu
-Given: 90
-Receive: 159
Reply #3 on:
May 21, 2011, 08:29:53 pm »
That's the way I would do it, can't see any point in taking the scuttle cover off to get to it.
Stu...
Peter85
Taking part
-Given: 0
-Receive: 0
Reply #4 on:
May 21, 2011, 08:33:38 pm »
was yours in the same place as above but got to it from above the pedals inside the car?
Last Edit: May 21, 2011, 09:52:36 pm by Peter85
alackofspeed
Always Involved
-Given: 6
-Receive: 24
Reply #5 on:
May 22, 2011, 11:50:40 am »
Quote from: Peter85 on May 21, 2011, 08:33:38 pm
It was in the same place as the CAN gateway in the link. The relay holder (has a relay with 100 printed on it, in the link) unclips, and can be moved aside. Unless you have absolutely enormous hands, it's fairly easy to reach through and grab the gateway.
Peter85
Taking part
-Given: 0
-Receive: 0
Reply #6 on:
May 22, 2011, 05:43:25 pm »
Found it thanks, had to lower the electronic box thing and remove the HVAC pipe
h4rdy
Reply #7 on:
May 22, 2011, 08:20:17 pm »
If it helps I have an 07 2007 ED30 with a 'K' revision canbus.
With an RCD510 I have no battery drain issues so it may be worth trying first before spending money upgrading it.
VCDS will also tell you the canbus revision.
Peter85
Taking part
-Given: 0
-Receive: 0
Reply #8 on:
May 22, 2011, 09:22:21 pm »
oh right great thats what mine is so hopefully i can swop without to much problem
Thanks again!
All Things Mk5
Mk5 General Area
