Author Topic: MFSW Parts missing? - Retrofitting MFSW Buttons  (Read 15761 times)
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
« on: May 28, 2011, 06:37:50 pm »
This afternoon I decided to try and fit my MFSW buttons. Taking all precautions I removed the airbag but I did not see what I had hoped. I understood it was a case of carefully removing the airbag and then simply plugging them in......not so, it seems :confused:
My car is an 06 manual and it seems like although I have both buttons and some sort of controller?? There doesn't appear to be a cable that connects them to the car?
This is what I have (buttons came from an 07 car):
What am I missing?
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: MFSW Parts missing? - Retrofitting MFSW Buttons
« Reply #1 on: May 28, 2011, 06:43:25 pm »
Pretty sure you're missing the airbag wiring loom for MFSW.
Stu...
Offline bodger00
  • -Receive: 20
« Reply #2 on: May 28, 2011, 06:49:20 pm »
Thanks Stu. I guessed it was something like that. So does this connect from the controller module (show in my first picture) to a point on the airbag?
I am not sure how this all fits together?? Will any coding be required?
Offline vRStu
  • -Given: 90
  • -Receive: 159
Stu...
« Reply #4 on: May 28, 2011, 07:16:17 pm »
I thought the only way you could get buttons to retrofit like this was on a DSG wheel, given that it has everything in place?
If you have a wheel, the only solution appears to be a new wheel with the buttons already fitted.
Offline bodger00
  • -Receive: 20
« Reply #5 on: May 28, 2011, 07:21:30 pm »
Thanks given Stu. So if I understand this right I need a MFSW Airbag Loom part no = 1K0 971 584 C and I may need a new steering wheel control module ??
I have midline clocks but I thought all GTI's had highline steering wheel modules? :rolleye:
Supposing I don't need a new steering wheel module, I guess its a case of airbag off......fit buttons and new loom and then refit without any coding?
Thanks for your help.
Stealth - I can't see any sockets to screw in the buttons on my wheel :confused:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #6 on: May 28, 2011, 07:24:12 pm »
I'd get the loom and fit it all up and see if it works before you go hunting for a Steering Controller.
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #7 on: May 28, 2011, 07:25:07 pm »
You do need to screw the buttons to the wheel.
Stu...
« Reply #8 on: May 28, 2011, 07:39:10 pm »
So it's actually possible to retrofit MFSW on a manual steering wheel?
Offline bodger00
  • -Receive: 20
« Reply #9 on: May 28, 2011, 07:40:01 pm »
I saw this on another thread which must have thrown me off track as this is a DSG wheel:
Great  :happy2: so I guess you can just clip them in.
Can anyone confirm what Stealth is saying? I would hate to think I am wasting my time with this wheel. There does not seem to be a place to clip in the thing I keep calling a controller?
« Reply #10 on: May 28, 2011, 07:42:35 pm »
The DSG wheel has blank covers which come off and can be swapped with MFSW buttons.
I've been led to believe (by this forum!) that it cannot be done with a manual steering wheel.
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #11 on: May 28, 2011, 07:47:50 pm »
stealth is right, unlike the VRS where I can see you had buttons just non functional.  In the Golf you cannot replace the black plastic blanks on the manual wheels as they are solid plastic.  if you get a wheel that has the cutt outs you will also need the airbag loom as stu has led you to believe.
« Reply #12 on: May 28, 2011, 07:50:52 pm »
stealth is right
Without offense to bodger, thank God for that! Honestly was starting to think I could have had MFSW all these years!  :grin: :stupid:
Offline bodger00
  • -Receive: 20
« Reply #13 on: May 28, 2011, 08:22:56 pm »
Cheers Rich.....I think that clears it up then.....unfortunately this is a PITA for me :sad1:
So I guess these buttons and controller are now for sale then if anyone wants them.....
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #14 on: May 29, 2011, 09:52:13 am »
It is a right pain Bodger, and I see no reason for them producing two different base wheels!  :fighting:
