Author Topic: When do you "feel" the boost?  (Read 8275 times)
Offline mattchaps
Re: When do you "feel" the boost?
« Reply #15 on: June 30, 2011, 03:47:50 pm »
K03: from around 1,800 revs today  :happy2:. But the boost gauge shows activity the instant I press the accelerator.
I know you have mods Robin, but your result still makes me think something isn't right with mine. To have to wait until 3k rpm before any real activity isn't right!
MkIV R32 Turbo - Gone but not forgotten -  Click here
MkV GTI - Arrived
Offline stu_no_1
« Reply #16 on: June 30, 2011, 08:50:56 pm »
When I had my gti it was always 2.5 before u felt any power and 3 when u felt it was on full boost, but I did have a boost leak at the end, I think it was diverter valve have you got any hissing noises or have you ever had your car vag com'd to see if there is any faults
Offline damoegan
« Reply #17 on: June 30, 2011, 09:46:16 pm »
A boost gauge is the only real way to to know  :happy2:
2/52 by Damoegan, on Flickr
« Reply #18 on: June 30, 2011, 10:54:00 pm »
....As soon as you remap a turbo'd car it's the feeling of boost which you experience. As Damo says, a boost gauge is a very reliable way of seeing what's happening.
Offline keano
  • -Given: 79
« Reply #19 on: June 30, 2011, 11:40:45 pm »
Is this your first turbo car?
Offline stu_no_1
« Reply #20 on: July 01, 2011, 08:23:22 am »
Buy an r32 no lag and sounds better :D
Offline mattchaps
« Reply #21 on: July 01, 2011, 08:50:25 am »
Nope, had an R32 and then turbo'd it! Admittedly the boost came on earlier in that and I'm aware I shouldn't expect the same, but I'm just surprised at how late it seems to come in on the GTI.
MkV GTI - Arrived
Offline mattchaps
« Reply #22 on: July 01, 2011, 08:52:17 am »
Hoping to get it vagcom'd soon, location and work make it difficult. But I have been hearing hissing noises from the turbo (DV) and they change as the revs increase.
MkV GTI - Arrived
« Reply #23 on: July 01, 2011, 09:20:55 am »
....It's beginning to sound as if you have an OEM DV, not the latest revision, and that the plastic diaphram is failing < Not an uncommon fault but more so on tuned cars. The diaphram splits/tears.
HTH
Offline mattchaps
« Reply #24 on: July 01, 2011, 10:10:01 am »
HTH
After changing plugs, coils and PCV I had a feeling this was next. Am booking her in to AmD Essex soon for some mods including the Forge DV. In the mean time I'm hopig VRS Carl can make his was over to vagcom her to see if there are any clues hiding!
Thanks Robin :happy2:
MkV GTI - Arrived
Offline bacillus
  • -Receive: 453
« Reply #25 on: July 01, 2011, 11:06:57 am »
In most instances, the latest oem version D divertor valve would work just as well as the Forge version with the added bonus of it being cheaper iirc around £40.
Offline derek
« Reply #26 on: July 01, 2011, 11:16:00 am »
does anyone have the part number for the new revised DV?
Offline mattchaps
« Reply #27 on: July 01, 2011, 11:23:07 am »
IIRC it's 06H 145 710D
MkV GTI - Arrived
Offline mattchaps
« Reply #28 on: July 01, 2011, 11:24:22 am »
Should I not bother going Forge then, will the OEM one cope with mild mods up to stage 2 remaps?
MkV GTI - Arrived
Offline bacillus
  • -Receive: 453
« Reply #29 on: July 01, 2011, 11:25:13 am »
06H145710D
