Author Topic: coil packs, new?  (Read 5137 times)
Offline chris s
coil packs, new?
« on: July 25, 2011, 04:55:46 pm »
Stupid question, but i have just bought some apparently new coil packs from ebay, should there be any grease at the end which fits over the plugs and would they totally smooth on metal, ie no
Candy White Edition 30 DSG
Revo Stage 2+
ITG, BCS TBE, Autotech HPFP
WALK
R32 Brake upgrade
S3 IC upgrade
Offline chris s
Re: coil packs, new?
« Reply #1 on: July 25, 2011, 08:13:28 pm »
Has no hot one bought any new coil packs? I'm not convinced the guy was totally honest no ebay
Revo Stage 2+
WALK
R32 Brake upgrade
S3 IC upgrade
Offline winrya
« Reply #2 on: July 25, 2011, 08:15:31 pm »
I bought new ones 12 months ago and they indeed has new grease on the ends on them
Offline andrewparker
  • -Given: 32
  • -Receive: 78
« Reply #3 on: July 25, 2011, 08:21:35 pm »
What exactly is a coil pack? I noticed VW changed mine when it was serviced recently, some recall apparently...
Offline m4t_lee
« Reply #4 on: July 25, 2011, 08:41:34 pm »
yes all petrol vw and audi engines 1.8 and above are under the vw recall, you should check with your dealer and get them swapped out if needed, you shouldnt need to buy any
06 Shadow Blue GTI
Offline baldwined30
« Reply #5 on: July 25, 2011, 08:56:14 pm »
Just had mine changed under recall! dont even know what they do  :ashamed:
Ed30
Offline edition_30
« Reply #6 on: July 25, 2011, 09:18:29 pm »
What was the recall related to guys?
Offline chris s
« Reply #7 on: July 25, 2011, 09:30:39 pm »
Coil Packs basically increase the voltage (think that is the right term) from the spark to a level higher enough to ignite the fuel in the cylinder
Revo Stage 2+
WALK
R32 Brake upgrade
S3 IC upgrade
Offline DJM
  • -Given: 28
« Reply #8 on: July 25, 2011, 09:39:39 pm »
Think people have had problems with some of the coilpacks, think people have experienced misfires at low revs.
Not 100% sure, no issues with mine but still booked in for them to be changed. Cant pass up opportunity for a full set of coilpacks free of charge lol.
« Reply #9 on: July 26, 2011, 12:53:10 am »
My coilpacks were spotless when I bought them from VW last week. There was grease on the ones I removed though!
Offline edition_30
« Reply #10 on: August 09, 2011, 06:46:27 pm »
In terms of the recall do i just contact vw and mention the misfire?
Was there a recall code?
h4rdy
« Reply #11 on: August 09, 2011, 06:55:25 pm »
They used to be called ht leads and plug caps connected to a distributor and coil.
They dumped all that for a coil pack which, I believe although maybe some gubbins in between, connect to the ECU directly to the coil pack which plugs into the spark plug.
« Reply #12 on: August 09, 2011, 07:14:28 pm »
Do a search for it but there was no official recall. Coilpacks would be swapped out if required at service time. Best thing is to go in and ask.
Offline martziniuk
« Reply #13 on: August 09, 2011, 07:25:48 pm »
service bulletin http://www.scribd.com/doc/51072764/28E9
I'm on the F coil packs on MY07 so sadly not affected  :sad1:
Mk2 Octavia vRS with K04 conversion, 3"TBE & Decat, APR HPFP, BDM Intake, S3 I/C, Sachs clutch & Unicorn custom map, S3 brakes, AP coilovers, THS mounts.
B8.5 Audi S4 with uprated pulley and unicorn Stage 2
Offline dajonic
  • -Given: 17
« Reply #14 on: August 09, 2011, 07:27:48 pm »
I called into my parts department for a seal under the bonnet and asked about prices for coil packs. The guy actually said I think there was a recall about these, let me go check. Result...booked in tomorrow morning.
