August 12, 2026, 11:14:59 am
All Things Mk5
Mk5 General Area
tyre wear
Topic: tyre wear (Read 1214 times)
revsevs
tyre wear
August 08, 2011, 10:51:01 pm »
my front tyres are showing quite a lot of wear from 5.0 in middle to 1.7 on about an inch on the outside
any thoughts on what the cause could be?
the back tyres similar but not as bad
tracking?
tyre pressure?
Frenzy
Won't Shut up.
-Given: 62
-Receive: 29
Re: tyre wear
Reply #1 on:
August 08, 2011, 11:16:27 pm »
tyre pressure would be my first port of call - especially with uneven wear. Easily tested and rectified, if PSI is correct then move on to other possible problem areas like alignment.
revsevs
Re: tyre wear
Reply #2 on:
August 10, 2011, 03:36:47 pm »
thanks for reply will check it out
Frenzy
Won't Shut up.
-Given: 62
-Receive: 29
Re: tyre wear
Reply #3 on:
August 10, 2011, 10:11:59 pm »
If i read what you typed in the 1st post correctly you are suffering more wear in the centre of the tyre than the outside which indicates that they are over inflated and that tyre pressure is the likely problem.
peter
Taking part
-Given: 2
-Receive: 1
Re: tyre wear
Reply #4 on:
August 12, 2011, 09:04:37 pm »
+1
ED30, Custom stage 1 remap, THS FR3 engine mounts, Helix clutch, AP coilovers, W.A.L.K, Powerfex lower front control arm bushes, Heko wind deflectors
All Things Mk5
Mk5 General Area
tyre wear
