Author Topic: Cruise Control fitting guide  (Read 53867 times)
Offline liver
Re: Cruise Control fitting guide
« Reply #30 on: November 11, 2011, 07:24:16 pm »
so after its fitted it will just need coding with no problems, great result, had the stalk for over a year and still havnt fit it yet. I can't find the bolt needed to get the steering wheel off
thanks for you knowledge ed
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #31 on: November 11, 2011, 07:28:14 pm »
as long as you have the diagnostic wire, just fit the stalk and code the steering control module and activate it in the engine
Cluster and Key coding
Location Great Yarmouth
Offline vRS_Pagey
  • -Receive: 59
« Reply #32 on: November 11, 2011, 07:30:26 pm »
Follow Jedi's guide mate and you can't go wrong, if you are anywhere near me I have all the required tools.   :happy2:
Offline jedi-knight83
  • -Receive: 41
« Reply #33 on: November 11, 2011, 09:33:54 pm »
AF is fine as its midline so supports cruise.
What year is your car... If its pre 06 you will need an extra wire... if its 06 build or later you should be fine.
Its all explained in my 'how to' (link on the first page of this thread)
Offline skard
  • -Receive: 245
« Reply #34 on: November 12, 2011, 12:09:59 pm »
As above.
I had a factory fitted AF module with cruise, using a midline cluster.
Offline DaveR77
    • UK-MKIVS.net
« Reply #35 on: November 13, 2011, 07:50:11 pm »
Where's the best place to get the spline bit from, do B&Q sell them?
« Reply #36 on: November 13, 2011, 07:54:00 pm »
IIRC i got mine from halfords on a rack of about 5/6 other sizes
Offline skard
  • -Receive: 245
« Reply #37 on: November 13, 2011, 07:56:40 pm »
I got a cheapo set from eBay, delivered for about a fiver. comes with short and longer bits of the same size.
The set I got is the same as this http://www.ebay.co.uk/itm/11PC-SPLINE-BIT-SET-1-2-DRIVE-SOCKET-CHROME-VANADIUM-/140630512900?pt=UK_Hand_Tools_Equipment&hash=item20be3b5504
« Last Edit: November 13, 2011, 08:29:32 pm by skard »
Offline vRS_Pagey
  • -Receive: 59
« Reply #39 on: November 13, 2011, 07:57:59 pm »
MPS
Offline sarahw
« Reply #41 on: November 13, 2011, 08:27:10 pm »
i have a 55 plate , i only needed the stalk if this help  :jumping:
Offline vRS_Pagey
  • -Receive: 59
« Reply #42 on: November 13, 2011, 08:34:03 pm »
Really?  Perhaps a previous owner fitted the diagnostic cable?
MPS
« Reply #43 on: November 13, 2011, 08:47:18 pm »
Just to warn people considering buying spline bit sets, a spline is different from an XZN bit, the difference is in the angle of degrees on the splines of the 2 types of bit. Whether there is enough of a difference to make it not fit the bolt however, I'm not sure. I used a 12mm XZN bit and that fitted 100%. You don't want anything slipping when it comes to torquing up the bolt.
Sorry if that made your head hurt, I just re read it and it did me. :confused:
« Last Edit: November 13, 2011, 09:21:08 pm by MPS »
Offline sarahw
« Reply #44 on: November 13, 2011, 08:49:45 pm »
nope it was me that got it retor fitted  :P
