Author Topic: ESP light cause...help.  (Read 1900 times)
Offline Richhero
« on: August 22, 2011, 09:30:36 am »
Could the ESP light being on (and excuse my complete lack of mechanical knowledge/jargon here) be caused by exposed wiring on the cable coming off the brake pad wear sensor and being shorted out in wet weather? Brother in law changed my front discs and pads on Saturday (having become hugely frustrated trying to get the rear caliper carrier bolts off whilst trying and failing to do the rears) and noticed that the wires are showing just after the plug.
Any thoughts? Ta in advance.
Offline bacillus
  • -Receive: 453
Re: ESP light cause...help.
« Reply #1 on: August 22, 2011, 10:14:54 am »
Sounds like he dislodged one of the connectors to abs front sensors whilst working on the brakes.
Offline Richhero
« Reply #2 on: August 22, 2011, 10:18:57 am »
Possibly, but the light has been on for about a week now so was just wondering if it could be a cause, assuming he didnt pull it out.
Offline bacillus
  • -Receive: 453
« Reply #3 on: August 22, 2011, 11:29:53 am »
Don't thinks so.
If the light was on before then you really need the car scanned to retrieve the stored fault code. The code should pin point the problem.
Offline crashdesk
  • -Given: 36
« Reply #4 on: August 24, 2011, 01:08:00 pm »
My light came on a week ago. Had to have ABS pump fixed with repair kit. Quite expensive so hopefully it's not that.
Offline Nickyboy
  • 2007 ED30 in Grey
« Reply #5 on: August 24, 2011, 01:16:30 pm »
Prob the ABS pump. I had the same problem but VW only charged me labour as goodwill due to the reliability issues of said part.
