Author Topic: High pitched noise on acceleration  (Read 23032 times)
Offline chris s
Re: High pitched noise on acceleration
« Reply #30 on: August 31, 2011, 08:50:46 am »
My experience is not an intake whine, as I don't have one... the noise appears when the car is in the lower gears and relatively low gears [1 -3]
Candy White Edition 30 DSG
Revo Stage 2+
ITG, BCS TBE, Autotech HPFP
WALK
R32 Brake upgrade
S3 IC upgrade
Offline baldwined30
« Reply #31 on: August 31, 2011, 08:55:15 am »
Mines in any gear! Not sure if it happens at full tilt but because all you can hear then is the zorst!!
Ed30
Offline Russ_leeds
« Reply #32 on: August 31, 2011, 10:24:38 am »
x2 I guess the whistle (or "hoot" in some instances) may just be induction noise around the 3k-4k mark. Happens on occasion.
[/quote]
i get this everytime when under load from my itg
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline baldwined30
« Reply #33 on: August 31, 2011, 11:27:56 am »
I have taken mine to AMD in essex and they said that if its not happeneing all the time then not to worry! That said I think I may take it back for them to have a look at on the ramps etc!!
Ed30
Offline cmdrfire
    • Commander Fire - my blog
« Reply #34 on: August 31, 2011, 11:44:46 am »
Seriously, turbocharged cars whistle and hoot and fart and burp and chaff and make all sorts of other funny noises. Don't worry until it breaks  :driver:
/this is probably bad advice
« Reply #35 on: August 31, 2011, 11:46:36 am »
^^^  :signLOL:
Offline oedo
« Reply #36 on: August 31, 2011, 11:50:48 am »
This will sound like (and is!) a silly question but how high pitched is the noise you are getting?
I have what I would describe as a high pitched buzz from my engine but only under gentle acceleration in lower gears up to about 3000rpm. Under heavier load it's not as noticeable. I too had wondered if this would be fuel pump related.
I've not been able to trace the source and beyond replacing random parts at great expense I've resigned myself to it being a 'feature' of the car and will just have to worry about it if or when it gets worse or something goes pop!
Offline Weston
« Reply #37 on: August 31, 2011, 11:53:46 am »
VW had a look at mine. Advice was to ignore it unless there's a loss of power or something breaks. Cheers then  :signLOL:
GTI going...
Offline oedo
« Reply #38 on: August 31, 2011, 12:15:47 pm »
I used to run a Volvo S60 with intergalactic mileage which made all manner of clunks, bangs, rattles, knocks and squeeks. I was told this was perfectly normal for an old Volvo... the point at which you start to worry is when it stops making noises!!  :laugh:
Offline Weston
« Reply #39 on: August 31, 2011, 01:13:08 pm »
^^^ Brilliant!  :congrats:
GTI going...
Offline AlanEdition30
« Reply #40 on: August 31, 2011, 01:27:41 pm »
My car has had this noise, but its gone for the last 6 months or so. Though i now have an ITG intake installed, so darth vader maybe hiding it  :laugh:
Offline baldwined30
« Reply #41 on: August 31, 2011, 05:39:29 pm »
Think maybe the twintake should of hid it but it hasn't, its not really high pitched! I did replace the cam follower as I also thought it may have been that but it wasn't! Plus I think if it was the pump then it would make it from tick over! I'm hoping its the return valve as maybe the HPFP is asking from more than it can give?? Either way its another mod I guess!!
Ed30
Offline johnboy07
« Reply #42 on: August 31, 2011, 05:59:23 pm »
where abouts are you mate as if your near to me i will quite happily help / fit it for you. Its a paint because the fuel lines need to be disconnected from the hpfp so that you can gain enough access but im sure i will find it easier second time round  :signLOL: im down in bournemouth. All i can say is i had the same problem and searched the net until i came accross the rs4 valve. spoke to APD who are vag tuning specialists and they said that shoudl sort the problem and it did. I was in the same situation and some people like above will say leave it till it breaks but i worry too much so found this as my solution.  :happy2:
Stage 2+ 280.4 bhp ITG, Revo Stage 2+, decat, hpfp, THS intercooler, THS engine mounts, Pcv revamp, sportline springs, rs4 fuel valve, DS2500 pads and brembo discs, braided lines, ATE super blue brake fluid and more to come
Offline baldwined30
« Reply #43 on: August 31, 2011, 06:27:18 pm »
Yea I worry too much as well! A hand would be really good! I'm In essex so no the end of the world! Got my S3 cooler to fit this weekend so in a few weeks that would be a great help! Especially from someone who's fitted it before!
Ed30
Offline johnboy07
« Reply #44 on: August 31, 2011, 06:43:58 pm »
no problem mate just message me and will sort something else. Make sure you have another pair of hands doing the cooler. Fit my THS a few months back and it would have been so difficult on my own. Only took a few hours too. It you struggle with anythin let me know as THS supply a manual for fitment. Shud probably get it up on the how to at some point. Just alot of scanning  :signLOL: :fighting2:
