Author Topic: Battery drain ?  (Read 1482 times)
Offline hoggj
  • -Given: 17
  • want to no more ??
Battery drain ?
« on: September 20, 2011, 04:56:17 pm »
Sorry I know no better..! I have just bought a rcd510 from a 2009 passat and i have a 2007gti i have read about battery drain, will i have any problems with this ? I had a rcd300 in the car. Plus how easy is it to swap them over ?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Battery drain ?
« Reply #1 on: September 20, 2011, 05:25:14 pm »
you probably will be ok, if you have vag-com you can scan the car to see which version is installed. Some K versions will drain so L or above you will have no issues
Cluster and Key coding
Location Great Yarmouth
Offline hoggj
  • -Given: 17
Re: Battery drain ?
« Reply #2 on: September 20, 2011, 05:34:57 pm »
Don't have vag.com is there another way of finding out ?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Battery drain ?
« Reply #3 on: September 20, 2011, 06:32:31 pm »
only by looking at it
Or
fit the radio and find out in a few days if you have drain
