Author Topic: Any ideas? Misfire?  (Read 20128 times)
Offline Weston
Any ideas? Misfire?
« on: September 22, 2011, 10:37:02 am »
Since my remap I've thought a few times that the car has been running a bit odd. Just now, slight incline, 30mph, 5th gear, 1500rpm & the engine seemed to be behaving strangely. The revs dropped slightly then came back. This happened all the way up the hill. If I put my foot down it runs fine and only does this occasionally. The other times have been less obvious.
Any ideas?
GTI going...
Re: Any ideas? Misfire?
« Reply #1 on: September 22, 2011, 10:57:58 am »
Random misfires are often a sign of a coilpack on the way out. Best to check (VAGcom log thingy) before it fails totally and potentially does damage.
Remapped 2.0T FSI engined cars should ideally have their plugs renewed every 10k miles.
Someone else will chip in re what else it could be.
Offline Weston
« Reply #2 on: September 22, 2011, 11:14:28 am »
Cheers  :happy2:
New plugs fitted in March, coil packs on the recall done in July
GTI going...
« Reply #3 on: September 22, 2011, 12:53:48 pm »
Then the next question might be which remap?
Someone who can laptop log would doubtless be able to help more than me.
Offline Weston
« Reply #4 on: September 22, 2011, 12:56:10 pm »
R Tech stage 1. I'll see if I can find a member with VCDS close to me (Bristol)
GTI going...
« Reply #5 on: September 22, 2011, 01:00:03 pm »
The R-Tech guy is normally very caring and helpful. But VCDS best starting point. Possibly a setting on the map but I'm guessing wildly.
Offline Weston
« Reply #6 on: September 22, 2011, 01:04:33 pm »
I know Nick will be more than happy to have a look for me, and I'm not suggesting it's the remap either as I've only heard positive things about them. I reckon the remap has possibly exposed a weakness somewhere, although my mechanical knowledge is zero.
GTI going...
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #7 on: September 22, 2011, 01:29:02 pm »
Is it running a bit lumpy at idle? PCV maybe?
Offline Weston
« Reply #8 on: September 22, 2011, 01:33:17 pm »
Idle seems fine. New PCV fitted at same time as remap, although that could be the issue. It makes some squeaks, which I think is caused by air in the PCV,
GTI going...
Offline bacillus
  • -Receive: 453
« Reply #9 on: September 22, 2011, 02:47:13 pm »
Cheers  :happy2:
Don't exclude a new faulty coil pack as one member on here found out...
Offline Weston
« Reply #10 on: September 26, 2011, 11:22:08 am »
Well I've scanned the car today and there's no codes at all  :confused:
GTI going...
« Reply #11 on: September 26, 2011, 11:58:21 am »
Sick of this myself every 3-5k miles now, need a health check to see if there's an underlying problem
Offline Weston
« Reply #12 on: September 26, 2011, 12:14:03 pm »
When yours does it what's it like?
GTI going...
« Reply #13 on: September 26, 2011, 12:40:52 pm »
Started off very slight when accelerating in 4,5 or 6th as if lost power for a fraction. 100 mikes later it was a prominent stutter. Switched to stock map to get to garage for new plugs
Offline Weston
« Reply #14 on: September 26, 2011, 02:51:23 pm »
Hmm maybe it's not the same thing. Mines very intermittent. I wonder if it's the DSG hesitating on a change?
GTI going...
