Author Topic: Exhaust gas warning light?! Now with fault codes!!!!  (Read 12000 times)
Re: Exhaust gas warning light?!
« Reply #15 on: October 01, 2011, 10:34:54 am »
I'm sure I pmd you, I didn't get one back.
Tomorrow morning anygood?
Offline scott84
« Reply #16 on: October 01, 2011, 10:55:18 am »
Erm yer should be fine mate, think I'll be alright to drive it?! I assume as it's only an Amber light it's not too serious as far as damaging the engine?!  :confused:
« Reply #17 on: October 01, 2011, 10:57:56 am »
Should be fine... can you get to harrow for 9:30?
Offline scott84
« Reply #18 on: October 01, 2011, 11:14:16 am »
Yer could get there for then, maybe not wide awake but ill be there!! Ha I'll pm u my mob number for u to forward your address.
Thanks for your help.
Offline scott84
« Reply #19 on: October 01, 2011, 08:41:56 pm »
Hi mate,
Quick update....went out to move my car about an hour ago and the light is no longer staying on!!!!
Could it have been some crap petrol or something?!
Do u think it's still worth scanning it or would I be wasting your time?!
« Reply #20 on: October 01, 2011, 08:43:52 pm »
IMO, for piece of mind it's always a scan  :wink:
Offline scott84
« Reply #21 on: October 01, 2011, 08:49:40 pm »
I don't mind either way.....never mind driving the gti !! Up to richwig83!! Just not as urgent without the light on if he's busy!!  :happy2:
Offline chowgar
« Reply #22 on: October 01, 2011, 09:17:57 pm »
Hi mate,
The light is on a key cycle and will turn off though the problem will still be logged... Have it scanned mate
Offline scott84
« Reply #23 on: October 01, 2011, 09:35:48 pm »
Yer I will. Unless richwig8 wants to re-arrange another time. But if I don't hear anything back I will be there for when we agreed.  :smiley:
Offline scott84
« Reply #24 on: October 02, 2011, 11:57:27 am »
Codes read by Rich today................
If anyone can make some sense of them it will be appreciated!  :happy2:
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 J    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0030
   Revision: 5BH15---    Serial number: VWZ7Z0F8120179
   Coding: 0403000318070060
   Shop #: WSC 00676 210 83490
   VCID: 2D5A0B02CD8A
2 Faults Found:
012599 - Intake Manifold Runner Control: Basic Setting not Completed
               P3137 - 001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 66334 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 55.0°C
                    Temperature: 53.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.192 V
001602 - Sensor Reference Voltage A: Circuit: Low
               P0642 - 002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 66334 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 55.0°C
                    Temperature: 53.0°C
                    Voltage: 12.319 V
Readiness: 0000 0000
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
Red ED35 5dr DSG
BLOG | BUILD
Offline bacillus
  • -Receive: 453
Re: Exhaust gas warning light?! Now with fault codes!!!!
« Reply #26 on: October 02, 2011, 02:04:52 pm »
Not meaning to disagree with John (above) but I would have thought that if the tumble flap has failed, the cel would remain illuminated.
IMO you should try a basic setting adaptation of the Intake Manifold Runner with vcds (detailed below) then rescan for fault codes after a short drive.
Prerequisites:
Ignition ON
Engine OFF
System voltage at least 11.0 V.
[Select]
[01 - Engine]
[Basic Settings - 04]
Group 142
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
Wait until Field 4 shows "ADP. O.K.".
[Done, Go Back]
[Close Controller, Go Back - 06]
Switch Ignition OFF for at least 60 seconds
« Reply #27 on: October 02, 2011, 02:08:50 pm »
Scott... has the light come back on again? Your more than welcome to come around again and we can try that basic settings adaptation that BACILLUS suggests.
« Reply #28 on: October 02, 2011, 02:18:53 pm »
It will probably clear following the Basic Settings but may well come back. These were problematic on the early BWA engines.
It wont clear without doing Basic Settings.  :wink:
Nasir
« Reply #29 on: October 02, 2011, 04:30:45 pm »
I just did this on my mates GTI, BWA engine on a 2006 car. Same faults, the light came on and off. I did the basic settings for him yesterday so we'll see if that helped. I did an output test on it as well, you could hear it operating. The car did feel quicker and more urgent, but it's all subjective.
