Author Topic: 2.0TFSI Oil Pick up pipe blocked = Low oil pressure warning  (Read 57089 times)
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
« on: October 17, 2011, 09:59:42 pm »
I thought I broke a 78k 2.0TFSI....  :sick:  I was happy custom mapping it from stock to stage2 power when the engine decided to cut out and give me a low oil pressure warning.  :jumping:  Panic set on for a few mins, only until I called the customer to ask him if it happend before, I was shocked   :surprised: when he said yes, just turn the ignotion on and off and it will be fine.. :happy2:
So if you have a 2.0TFSI get your oil pick up pipes checked out, it looks like they are going to be worse than the 1.8Ts in the long run.  IMO if you have 80k+ and for what it costs get it replaced.
Oil pick up fixed engine flush and new oil & filter.. = happy tuner, happy customer and a nippy little A3.
« Last Edit: October 17, 2011, 10:06:34 pm by R-tech-Nick »
R-Tech Performance Tuning & Rolling Road Centre
Custom ECU Remap Tuning Specialists
1.8T - 1.9TDI - 2.0TFSI - 2.0TDI - DSG
Hinckley Leicestershire LE10 3BY
01455 617233
We aim to be the best not the biggest!!
8AD1691 - 1000101011010001011010010001 - 8AD1691
www.sticky-vnt.co.uk www.removal-dpf.co.uk
Offline Gti_Mad
Re: 2.0TFSI Oil Pick up pipe blocked = Low oil pressure warning
« Reply #1 on: October 17, 2011, 10:03:39 pm »
whats it blocked with???
« Reply #2 on: October 17, 2011, 10:03:57 pm »
thought he would of mentioned it or get it fixed before the remap :stupid:
« Reply #3 on: October 17, 2011, 10:04:44 pm »
looks like sludge
Offline keano
  • -Given: 79
« Reply #4 on: October 17, 2011, 10:07:18 pm »
What does this oil pickup do then?
Offline R-tech-Nick
  • -Receive: 30
« Reply #5 on: October 17, 2011, 10:11:20 pm »
You will be shocked by how many customers who try to hide issues from me, they know if it aint 100% I wont risk mapping there car, but they seem to be willing to take the risk.
Its just blocked up with general carbon build up and engine swarf, the inside of the sump was thick with built up gunk, on the the 1.8T engine i see it worse on cars which dont have dealer service history and £4.99 5lt oil get used along with a aftermarket oil filter.
01455 617233
Offline R-tech-Nick
  • -Receive: 30
« Reply #6 on: October 17, 2011, 10:13:43 pm »
Its a feed from the oil pump to the oil in the sump of the engine, its has a corse filter to stop bits going into pump, but from what I have seen the design of the pick up pick just holds on to all the gunk.
01455 617233
Offline keano
  • -Given: 79
« Reply #7 on: October 17, 2011, 10:15:17 pm »
Well I never knew that! (along with many most other things)
Cheers Nick  :happy2:
Offline R-tech-Nick
  • -Receive: 30
« Reply #8 on: October 17, 2011, 10:21:16 pm »
Now you do dude  :happy2:  Maybe this info will help you one day.
The oem parts to fit a new pick up cost less than £40
01455 617233
Offline Dario
  • booosting... :)
« Reply #9 on: October 18, 2011, 12:22:00 pm »
whats the part number for it ?
REVO ST2+ Edition30 -sold
soon 2015 Golf R :)
Offline R-tech-Nick
  • -Receive: 30
« Reply #10 on: October 18, 2011, 01:38:11 pm »
SD176404A2 = SEALANT  RRP £17.05+VAT
06F115251A = OIL PICK UP  £21.76+VAT
01455 617233
Offline Dario
  • booosting... :)
« Reply #11 on: October 18, 2011, 02:57:17 pm »
soon 2015 Golf R :)
« Reply #12 on: October 20, 2011, 11:27:09 am »
Thanks Nick for sharing it with our members.   :happy2:
« Last Edit: October 20, 2011, 04:10:01 pm by Top Cat »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #13 on: October 20, 2011, 01:02:42 pm »
Probably another good reason to avoid Long Life servicing.
Stu...
Offline robdf2
« Reply #14 on: October 20, 2011, 01:15:21 pm »
Is this a sump off job?
if so do you need a new sump gasket ? or is it a wet gasket?
2008 Chrono yellow Cupra
