Author Topic: T&D service interval from longlife  (Read 1541 times)
Offline chocice
« on: November 04, 2011, 09:27:44 pm »
Hi,
I discovered the trick for looking at when the next service is due, eg. hold down odometer and turn key, guess what it says service now! I tried to clear it as it was serviced 2 months ago but as it was originally on a long life service plan its not clearing, is there a diy way of changing the computer to T&D service intervals?
Re: T&D service interval from longlife
« Reply #1 on: November 04, 2011, 10:48:06 pm »
You need VCDS or ask the dealer to do it at the next service.
Offline chocice
« Reply #2 on: November 05, 2011, 03:18:35 pm »
where can I get VCDs? is ebay a good place?
« Reply #3 on: November 05, 2011, 03:37:05 pm »
The only people who make and develop the original one are ross-tech. Costs around £200-250 but you get lifetime support and can send them logs etc and they will help you out with fault codes.
The ones on egay tend to be fakes/ chinese copies that have to use cracked or outdated software to use. A few have bought them and then had to fork out again for the genuine version.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #4 on: November 05, 2011, 03:38:51 pm »
..........if the engine is set to the correct service interval & you do this check i take it it will change back to the normal display after?. :smiley:
Offline Oli
  • -Given: 19
« Reply #5 on: November 05, 2011, 04:39:29 pm »
Long life can only be reset from vagcom, but I'm sure T and D is done by a button pressing exercise. I will check my auto data on Monday.
