Author Topic: Can I retrofit the mk5 R32 speakers to my Mk5 fsi match?  (Read 1949 times)
Offline ripmateyy
« on: November 21, 2011, 09:07:00 am »
I know someone selling the 3 way front door speakers from a Mk5 R32. Was wondering is one it could be easily done and two if it would be worth doing?!
Jack
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Can I retrofit the mk5 R32 speakers to my Mk5 fsi match?
« Reply #1 on: November 22, 2011, 06:44:00 am »
Hi
I did this for someone not long ago
You will need to change the wiring and add the crossover units to each front door
Cluster and Key coding
Location Great Yarmouth
Offline daveangel
« Reply #2 on: November 24, 2011, 07:34:59 pm »
you will ned to remove the outer door skins to change the door wiring loom.  its not bad to do though.
Offline ripmateyy
« Reply #3 on: November 27, 2011, 12:51:50 pm »
Cheers guys, he sold them now so can't do it anyway, are they any good or would I be better off buying some focal or
JL 3 ways!
Offline daveangel
« Reply #4 on: November 27, 2011, 01:07:36 pm »
the only thing the factory loom gives you is the crossover and mid cabling.  i would say its far easier to rewire the door speakers with the crossover that will comw with whatever you decide to buy.  i did what you suggested and now im building a patch cable to interface the rainbow crossovers to the door wiring.  i would have neeb easier to go with rainbow first.  that and factory speakers are sh*teeeee
