Author Topic: GTI & EDITION 30 BADGE IN FRONT GRILL  (Read 3834 times)
Offline vagmaster
« on: December 10, 2011, 12:37:10 pm »
Hi guys, I'm curious as to how people get there GTI & ED30 badge to fit the front grill.
I have bought body filler plastic spatulars as I got told to stick them to on with glue, but as I look at the two it seems like it will drop off via car wash etc as there is not much room to play with.
If anyone can help it would be appriciated
thanks
Offline ktlstar
Re: GTI & EDITION 30 BADGE IN FRONT GRILL
« Reply #1 on: December 10, 2011, 12:42:48 pm »
Double sided tape does the trick!
- #1240 ED30 Revo STAGE2+
- Southeast - Vag Com owner
Offline vagmaster
« Reply #2 on: December 10, 2011, 01:00:30 pm »
Meaning the reg plate strength or by using the same which is already stuck to the badge
Offline sanj
  • -Given: 17
« Reply #3 on: December 10, 2011, 01:15:57 pm »
I used the sticky backing pad which is already on the badge when you get it,it's been through quite a few jetwashes and crap weather and it's still there,only thing is if some low life want's it he'll quite easily take it.
« Reply #4 on: December 10, 2011, 01:28:21 pm »
The GTI badge comes on a plastic backing which clips into the correct spot on the GTI grille. The ED30 badge - some have stuck it straight on, some have glued on a wire wrap and then used that, some have used a glue gun.
On my show grille, I've just stuck it straight on.
Offline Tamiyoman
  • -Receive: 39
« Reply #5 on: December 10, 2011, 03:59:36 pm »
My front Ed30 badge is still in its packet, will get iut stuck on the front when the weather warms up a little (aroud May 2012)
Offline maxload
  • -Given: 41
  • -Receive: 29
  • Edition30 - No.1819
« Reply #6 on: December 10, 2011, 04:24:03 pm »
Super glue FTW  :happy2:
Offline Sug
« Reply #7 on: December 10, 2011, 07:06:58 pm »
I took the adhesive cover off stuck it on where I wanted it and then pulled it straight back off, this leaves grooves on the pad from the mesh grill. Thin layer of super glue on the grooves and pop it back on. Jobs a good en!  :happy2:
EDITION 30 GONE, MK6 R GONE........AUDI 8V S3.....Stock for now
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #8 on: December 10, 2011, 08:58:14 pm »
Just stuck mine on with the sticky pad on the back of the badge.
