September 28, 2026, 01:52:42 pm
All Things Mk5
Mk5 General Area
Oil filler doesn't line up on engine cover exactly ?
Topic: Oil filler doesn't line up on engine cover exactly ? (Read 1712 times)
mad_pete
Always Involved
-Given: 3
-Receive: 1
December 30, 2011, 01:36:31 pm »
My oil filler cap isn't in the middle of the engine cover. It's not a problem but normally german engineering is very exact. Is this normal ? Just got my car and under closer inspection it's been bounced off a few things it in it's time and whoever serviced it last didn't manage to even put the air filter cover on properly so now I'm paranoid and checking everything.
stealthwolf
Just look at my post count
-Given: 306
-Receive: 292
ED30 No.1412
Re: Oil filler doesn't line up on engine cover exactly ?
Reply #1 on:
December 30, 2011, 01:48:21 pm »
Do you mean height wise? If so, no. Mine sits slightly higher or lower (can't remember which).
The
GTI
isn't just a machine. It's very much a living, breathing thing.
mad_pete
Always Involved
-Given: 3
-Receive: 1
Reply #2 on:
December 30, 2011, 02:00:15 pm »
it's off center so the oil filter isn't in the middle of the oil filter hole and it catches slightly on the cover as you pull it out.
RENNTAG
Won't Shut up.
-Given: 15
-Receive: 23
Premium Performance Parts
Reply #3 on:
December 30, 2011, 02:30:12 pm »
may be best to get some pictures up if you can
MPS
Reply #4 on:
December 30, 2011, 03:09:45 pm »
Something weird is bugging me with my oil cap as well, when it screws down it screws on so its sitting vertically instead of across the engine, a minor thing I know but I see it every time I open the bonnet and I'm very anal about such things!
baldwined30
Won't Shut up.
-Given: 1
-Receive: 7
Reply #5 on:
December 30, 2011, 08:27:26 pm »
Dont worry. The engine cover sits on rubber bungs! So a few MM either way wont matter!
Ed30
mad_pete
Always Involved
-Given: 3
-Receive: 1
Reply #6 on:
December 30, 2011, 11:30:44 pm »
Yes I had the cover off (Do the late models only clip at the front ? The rear metal cover mounts are smooth on mine and that confused me when trying to clip 4 back on) I can't see how it would get to be a few mm out though. I'll check for adjustment on the front mount positions.
sub39h
-Given: 189
-Receive: 84
Reply #7 on:
December 31, 2011, 11:43:14 am »
mine does this, and then the other day the top bit came off in my hand
the bit with the "grip" on it that you turn separates from the bit that actually locks into the filler neck. you can take it off and realign it. i did this the other day. it just clips back on
MODS
: '09 tail lights | TT vents | Bilstein B14 | RNS-E 2010 | AMI | AKS Tuning custom CAI | Titanium BBS VZs | NQS BBK | WALK | Autotech RARB | Bluemotion aero | Blueflame TBE | Autotech HPFP | MY11 Wing Mirrors | Bluetooth | S3 Intercooler
PLANS
: Stage 2+
All Things Mk5
Mk5 General Area
