Author Topic: Cruise Control - Resume previous speed?  (Read 2785 times)
Offline john87
  • -Receive: 53
« on: January 10, 2012, 12:26:37 pm »
I noticed when driving my dad's 07 Touran that one can resume the previous set speed even if the engine has been turned off and back on, which isn't the case in the golf or my last car with cruise control  :confused:
just to confirm, it is normal for the last set speed to be erased when the engine is turned off, even if the CC lever is left in the 'ON' position?
Offline alexperkins
  • -Receive: 99
Re: Cruise Control - Resume previous speed?
« Reply #1 on: January 10, 2012, 12:46:55 pm »
Id have to check in mine, but I'm pretty sure it remembers the last speed providing the CC lever is left on ON though it may be both ON or OFF
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Re: Cruise Control - Resume previous speed?
« Reply #2 on: January 10, 2012, 01:28:20 pm »
On my mk5, the cruise remembers the last set speed and can be resumed by pressing the top RES button. Think it only remembers the current session, eg. If you turn ignition off, it is lost and will set to current speed.
Jas
VCDS (Preston, Lancashire)
« Reply #3 on: January 10, 2012, 09:29:22 pm »
As above, has to be set at the required speed after each ignition on but will double check tomorrow.
The white MFD actually shows the speed the cruise is set at, which is quite impressive IMO.
Offline john87
  • -Receive: 53
« Reply #4 on: January 12, 2012, 12:28:13 pm »
Jas
This is what I was hoping to hear, and sounds the most logical solution...just found it odd that the touran was different!
