Author Topic: Brakes gt sport TDI!  (Read 4483 times)
Offline neil86
« on: January 12, 2012, 09:02:01 pm »
More questions for you lot to help with, i will be replacing my rear discs and pads soon, (fronts eventually) and wondered whats a good upgrade?
Either vented or drilled discs, descent pads.
Maybe upgrade to larger oem, but what would i need?
Cheers guys
Offline neil86
Re: Brakes gt sport TDI!
« Reply #1 on: January 13, 2012, 03:45:48 pm »
No one?
Offline Beddie
  • -Receive: 76
« Reply #2 on: January 13, 2012, 04:04:42 pm »
Personally i wouldnt spend a huge amount on the rears, good quality oem spec discs and if you fancy a fast road pad something like the Hawk HPS are pretty good and inexpensive for the rear  :happy2:
Easiest larger rear oem upgrade would be the 286mm solids from the GTi/Cupra, discs calipers and carriers required although you may get away with retaining your caliper but not 100% on if it is the same tbh (assuming you have the 232mm rears now?)
Carbon Grey Edition 35 - Here
Offline neil86
« Reply #3 on: January 13, 2012, 08:55:52 pm »
Ok will measure them up and see what I have, like the sound of maybe just the gti upgrade if I have the same calipers maybe?
Offline Beddie
  • -Receive: 76
« Reply #4 on: January 13, 2012, 09:05:22 pm »
At the very least though you will need the GTi carriers to space the caliper out to clear the bigger disc,
Even if you cant retain your original calipers then a full used rear set up from a GTi/Cupra should be fairly inexpensive i'd have thought  :happy2:
Offline neil86
« Reply #5 on: January 14, 2012, 08:11:16 am »
Will look into that fancy doing a small upgrade to be honest
« Reply #6 on: January 14, 2012, 08:17:26 am »
Beddie….. Will the full GTi front/rear brakes go straight on the TDi's?
Ive got the job lot in the garage that I need to shift soon.…calipers,carriers,disc's,pad's,hoses,etc
Offline Beddie
  • -Receive: 76
« Reply #7 on: January 14, 2012, 08:38:22 am »
Yeah mate it's a straight upgrade for the 288mm setup on the 140 tdi etc  :smiley:
« Reply #8 on: January 14, 2012, 08:41:57 am »
Monte
« Reply #9 on: January 14, 2012, 08:42:33 am »
Cheers mate. Someone asked me a while back, but I didn't know.  :ashamed:
Offline neil86
« Reply #10 on: January 14, 2012, 06:06:58 pm »
How will i know or is there a part code, on the calipers to let me know if my calipers are gti ones with smaller carriers
Offline Action jackson
« Reply #11 on: January 14, 2012, 06:14:19 pm »
I'd buy them brakes if your selling
Offline Beddie
  • -Receive: 76
« Reply #12 on: January 14, 2012, 06:15:51 pm »
Someone like DaveB (aka Prof. Friction) will tell you instantly or failing that a quick ETKA cross reference should tell you  :smiley:
Offline neil86
« Reply #13 on: January 14, 2012, 07:14:45 pm »
Etka? Is that the parts list
Offline Beddie
  • -Receive: 76
« Reply #14 on: January 14, 2012, 07:28:44 pm »
Yeah it is mate  :happy2:
