Author Topic: Boost Leak, Symptoms?  (Read 16373 times)
Offline nezquick
Re: Boost Leak, Symptoms?
« Reply #15 on: February 13, 2012, 08:39:04 pm »
Started googling but limited to phone at the moment. does anyone know any links or best to get them? would i be best of finding out from the horses mouth and dropping into a steakers tomuro and ask the technician for the info?
« Reply #16 on: February 13, 2012, 08:40:15 pm »
They wont know.... best to ask on here, maybe start another thread "boost pressures on stock GTI"
Offline nezquick
« Reply #17 on: February 13, 2012, 08:47:13 pm »
Hmm will do no me thinks. apparently tge quickest way to tell is if you have a stock gti the vaccum should show 20 or very close to 20. Mine do es so perhaps the dv is gone ill check tomuro. i also dod the pcv test and thats sweet.
Offline Sie
« Reply #18 on: February 13, 2012, 09:09:01 pm »
What's pcv test?
Here a link to a chap with similar prob
http://www.mk5golfgti.co.uk/forum/index.php/topic,29245.0.html
Sie
Fettled Laser Blue '05 GTi 5dr
Offline nezquick
« Reply #19 on: February 13, 2012, 09:12:35 pm »
Thanks ill read the thread in a min! Let the car idle and pull the dipstick out and the engine should run rough or chockey. if it continues to run smooth then you need a new one. theres quite a few threads on it and other tests and effectd symptoms etc
Offline nezquick
« Reply #20 on: February 15, 2012, 05:48:40 pm »
I got this on my scan today, anyone want to shed some light? should I just clear all the faults and hope for the best or does something actually need replacing?
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: ----------- Mileage: 116810km/72582miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115     HW:
   Component: 2.0l R4/4V TFSI  00 0070
   Revision: --H01---    Serial number: VWZ7Z0D1220341
   Coding: 0403000318070060
   Shop #: WSC 00607 210 71741
   VCID: E3C12BBF5BC5
2 Faults Found:
000665 - Boost Pressure Regulation: Control Range Not Reached
               P0299 - 002 - Lower Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 115422 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:37:28
             Freeze Frame:
                    RPM: 3718 /min
                    Load: 84.3 %
                    Speed: 52.0 km/h
                    Temperature: 87.0°C
                    Temperature: 22.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 14.224 V
000256 - Mass Air Flow Sensor (G70): Supply Voltage
               P0100 - 004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 5.0°C
                    Temperature: 5.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.938 V
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 3A7F36DB0CCF
1 Fault Found:
01314 - Engine Control Module
            013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AB
   Component: ClimatronicPQ35 066 0404
   Shop #: WSC 00000 000 00000
   VCID: 67D9BFAF2FFD
No fault code found.
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001309029
   Coding: E58D0F0600041800001400001400000000087F075C
   VCID: 3A7F36DB0CCF
   Part No: 1K2 955 119 B
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00000
   Part No: 1K0 955 559 M
   Component: RegenLichtSens 005  0605
   Coding: 00218142
   Shop #: WSC 00000
1 Fault Found:
00061 - Footwell Lights
            012 - Electrical Fault in Circuit
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 C    HW: 1K0 909 605 C
   Component: 08 AIRBAG VW8   013 2100
   Revision: 02013000    Serial number: 0033HD0316KN
   Coding: 0012344
   Shop #: WSC 01269 785 00200
   VCID: 2C530083F69B
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
   Component: Lenksäulenmodul 521 0050
   Coding: 0000012
   VCID: 356525E725D1
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 960 D
   Component: KOMBIINSTRUMENT VDD 0812
   Coding: 0003403
   Shop #: WSC 00607 067 57207
   VCID: 306B14F3DAB3
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104C02079E
   Coding: 3D3F0340070003
   VCID: 295DF997F969
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 0812
   VCID: 306B14F3DAB3
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0148
   Coding: 0000052
   VCID: 306B14F3DAB3
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 H
   Component: EPS_ZFLS Kl.12      1502
   VCID: 316D11F7D1B9
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 81C802087F2D8505485FC69010
   VCID: 7BF1F3DF4375
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H02 1301
   Part No: 1K0 907 719 B
   Component: Neigungssensor  004 0003
   Part No: 1K0 951 177
   Component: Innenraumueberw.004 0101
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Component: Tuersteuergeraet 09 0154
   Coding: 0000052
   VCID: 316D11F7D1B9
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 L
   Component: Radio BVX       012 0022
   Coding: 0040402
   VCID: 2F69178FC78D
1 Fault Found:
00872 - Bass Speaker Rear Left (R15)
            011 - Open Circuit
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0213
   Coding: 0000016
   VCID: 306B14F3DAB3
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
   VCID: 316D11F7D1B9
1 Fault Found:
00935 - Electric Window Motor; Rear Right (V27)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
End   ---------------------------------------------------------------------
THANKS IN ADVANCE!
« Reply #21 on: February 15, 2012, 08:39:20 pm »
With all fault codes, Clear them all, drive the car for a few days and See  which ones show up again.
