Author Topic: Some advice please guys  (Read 3471 times)
Offline jimlad09
« on: February 26, 2012, 04:20:54 pm »
I have decided after the recent spell of bad weather and constant cleaning of my car that i need to increase the amount of cleaning i undertake.
I want to purchase a clay bar kit and a high quality wax to be applied less regularly than my autoglym aqua-wax, a heavier duty wax.
I have looked at a number of products but would just like some advice over which to buy,
so far its either the meguiars quik clay kit or the autoglym surface detailing kit
as for wax i would like some suggestions. Mid range that delivers a good finish, im not too anal but would like a quality result
many thanks, James
Re: Some advice please guys
« Reply #1 on: February 26, 2012, 04:33:35 pm »
90% of the finish is in the preparation of the paintwork before LSP.
The Megs clay is fine but you'll quickly go through the lube. I can use half a bottle on the car. Alternative is Bilt Hamber, for which you can use water as lubrication.
Wax depends on your cost but doesn't last very long. Alternatively go for a sealant such as FK1000P, Powerlock, Jetseal or alternative eg 476s.
Offline jimlad09
« Reply #2 on: February 26, 2012, 04:47:03 pm »
Thanks for the help!
So Bilt Hamber clay bar and a decent sealant (as you list) will help improve my current finish, and i presume that any additional wax is added on top of a sealant?
Its only really the rear of the car that has a lot of contamination and slight greying from prolonged exposure to salt etc is starting to appear
Offline Daffy
« Reply #3 on: February 26, 2012, 06:11:58 pm »
If you want a wax that you can apply and forget about try Collinite 845. It is exceptionally hard wearing but wont give the paintwork the 'bling' effect of less hard wearing waxes so it is a compromise as to how often you are prepared to put the work in.
Offline jimlad09
« Reply #4 on: February 26, 2012, 06:19:40 pm »
Thanks, I think im going to aim for mid range in terms of price and performance. Like it said its more about the care of the paint work than aesthetics...but it does feel good when its got a flawless shine...decisions.
Appreciate the feedback guys
Offline GINGER224
« Reply #5 on: February 26, 2012, 06:40:44 pm »
 I've tried a few waxes and settle for dodo juice hard candy (as I have a light, medium and dark car) and I'd say it does give a decent shine, but I do use AG EGP prior to it and depending on weather etc it can last a few months.
Offline nathangallo
« Reply #6 on: February 26, 2012, 07:37:47 pm »
I use egp also do you just apply the wax on after this?
Offline Hilla
« Reply #7 on: February 26, 2012, 08:05:16 pm »
Another thumbs up for the Collinite here; I apply it once every 2-3 months as a top up and it does the trick. Makes cleaning a lot easier too!
« Last Edit: February 26, 2012, 10:59:09 pm by Hilla »
Offline gizmo68
  • We're here for a good time, not a long time
« Reply #8 on: February 26, 2012, 08:15:55 pm »
Another thumbs up for the Collinite here; I apply it once every 2-3 weeks as a top up and it does the trick. Makes cleaning a lot easier too!
:surprised:
You are either not using it correctly, using too harsh an TFR or simply just wasting that!!
VCDS HEX-NET & VCP owner (covers all VAG cars)
(PM me if you require VCDS or VCP coding or scanning in Kent)
« Reply #9 on: February 26, 2012, 08:16:54 pm »
+1. Two layers of collinite (476s) lasted me four months. Very durable. You do not need to keep topping it up!
Offline Frenzy
  • -Receive: 29
« Reply #10 on: February 26, 2012, 10:21:47 pm »
After: Yes, but if you can allow the EGP a bit of time to bed in before putting the wax on it. Last time i used EGP then waxed i gave it just short of 24 hours before applying the wax. Not saying you have to do this but i got good results from it.
« Last Edit: February 26, 2012, 10:23:34 pm by Frenzy »
Offline Hilla
« Reply #11 on: February 26, 2012, 10:57:49 pm »
Haha! Just re-read my post, I meant to say months not weeks! I definitely don't want to be topping it up every other week!  :laugh:
Offline jimlad09
« Reply #12 on: February 27, 2012, 10:30:42 pm »
Thought that seemed a bit OCD...didnt want to say anything  :scared:
Thanks for pointing me in the right direction guys, I decided to go for a couple of Poorboys products with the Bilt Hamber clay. Also treated myself to some Dodo Juice towels and wax applicator
« Reply #13 on: February 27, 2012, 10:58:39 pm »
I think if you could get to grips with Supernatural Hybrid with an occasional Red Mist top up it would last quite some time.  :smiley:
Offline jimlad09
« Reply #14 on: February 27, 2012, 11:06:01 pm »
Yeah? il have a play with the new gear when it arrives and see if im left wanting more. Supernatural hybrid is that a wax? and the Red Mist is a detailer? Think the red mist might make its way into the shed
