Author Topic: How to change the rear washer jet direction to i.e. 2 o'clock?  (Read 7473 times)
Offline Insanekiwi
Hi fellow owners.
I also have condensation on the high level light, and at the moment all the bulbs still work well. So I heard that it's due to rear washer jet directly shooting at the lights. Someone suggested changing this direction, but how do I go about doing that? Do I need to undo the bolt first then change the direction?
Thanks.
Re: How to change the rear washer jet direction to i.e. 2 o'clock?
« Reply #1 on: March 11, 2012, 09:46:45 am »
Use a pin, insert it into the jet nozzle and move the pin to adjust the direction.
That is presuming that the nozzle has not seized.
Offline Insanekiwi
« Reply #2 on: March 11, 2012, 09:54:25 pm »
Thank you. I will give it a go after work today. :)
Offline damoegan
« Reply #3 on: March 11, 2012, 10:18:53 pm »
Thats how I have always dont it too  :happy2:
Offline Insanekiwi
« Reply #4 on: March 12, 2012, 04:40:32 am »
Thanks - it seems to move. But there is not much play in there as the nozzle can move - but the black bezel that surrounds the nozzle limits the extent in can change the direction to. Also if you put it too forward to aim at the screen - it interferes with the wiper cap. I have put it at 1 olock, and it seems to just avoid the third brake lights.
Wonder if anyone tried - siliconing the edge of the third brake lights when they are working?
Offline lee_
« Reply #5 on: March 12, 2012, 08:41:14 pm »
I haven't had a rear wiper for at least 12 months and the brake light is still full of water! :sick:
Offline Geoffcarragh
« Reply #6 on: March 16, 2012, 05:51:29 pm »
You can use a pliers to turn the hexagonal nut that houses the jet assembly.
'05 Silver, 5 door, 18'' Monza II, Leather, Lux Pack, Gear Stick, CD changer in armrest, colour coded rear bumper, upgraded DV,
MPS
« Reply #7 on: March 16, 2012, 06:42:30 pm »
Hi fellow owners.
Thanks.
Anything you try will be fairly futile - I adjusted the angle of mine for the same reason and the wiper blade just flicks washer fluid straight up onto the light anyway. Another dumb design by VW. It wouldn't matter if the unit had better ingress protection.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #8 on: March 17, 2012, 05:04:38 pm »
My ED30 gets a bit of condensation in over the winter but is dry again now & my washer jet is no where near the brake light.
