Author Topic: cam adjuster, chain + tensioner  (Read 1031 times)
Offline mato
« on: March 13, 2012, 05:25:06 pm »
can anybody tell me if you change the cam chain and tensioner does the adjuster need to be done to? just had chain and adjuster done and i have lost stacks of power now the garage said the adjuster needs to changed????
Offline bacillus
  • -Receive: 453
Re: cam adjuster, chain + tensioner
« Reply #1 on: March 13, 2012, 06:09:36 pm »
afaik you should change rollers and tensioner with the cambelt.
If you've lost power then I suspect the alignment of the camshaft/crankshaft wasn't spot on when the belt was put on.
Offline vRSAlex
  • -Receive: 253
« Reply #2 on: March 13, 2012, 09:22:05 pm »
Can you give us some background of the issues?
The variable adjuster on the exhaust cam is very reliable and Ive only ever replaced one due to the mounting pin snapping on removal.
Follow AKS tuning on Facebook
