Author Topic: exhaust, or bearing sound on 55 plate gti dsg 2.0  (Read 2106 times)
jaz
« on: March 13, 2012, 09:43:49 pm »
Hi Guys,
The CAR: I've got a mk5 GTI 55plate DSG 66k miles.
Problem is excessive noise - It's recently become more noticeably more louder from what sounds like an exhaust sound which increases upto 70mph then goes away  the sound is so loud.. that  only a stereo can drown it out  when the speeds are in the 60mphs.
I'm a bit baffled as an inspection of the exhaust under throttle has revealed no holes.  could it be a bearing?
Any pointers would be much appreciated.
Cheers, Jaz
Offline 56OctyVRS
  • -Receive: 72
Re: exhaust, or bearing sound on 55 plate gti dsg 2.0
« Reply #1 on: March 13, 2012, 10:23:59 pm »
Does the sound increase with the engine or gearbox speed? Also consider a constant velocity joint.
jaz
« Reply #2 on: March 17, 2012, 05:42:14 pm »
Fixed... it was worn bearing. :laugh
Took it into an powerflow garage toda, they had a look seeing there was no exhaust probelm, we' proceeded to a  test drive and all agreed there was rasp like, with a lot of speculation for bearing failure in DSG box... with lots of head-scratching and  back on the ramp's I'd intervened spinning each wheel, to find  one o/s/r wheel gave a slight rasping sound (but no lateral bearing play) . swapout £97.20 (OEM bearing ) + £50.00 installtion fixed it. :happy2:
