Author Topic: Nothing but trouble since i bought it!!!  (Read 8278 times)
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Nothing but trouble since i bought it!!!
« Reply #15 on: April 06, 2012, 08:59:20 pm »
tuner wise you've also got the option of R-Tech in Hinckley. they know their stuff, and they're a great bunch of lads
PLANS: Stage 2+
Offline vRSAlex
  • -Receive: 253
« Reply #16 on: April 06, 2012, 09:47:43 pm »
Funnily enough I also have a cylinder 3 missfire that looks to be a faulty injector.  I have a new one turning up next week.
I've got some spare used GTi injectors in stock if its for a 200 bhp car and I can do brand new s3 injectors for 70 quid each.
R tech are the closest to you, but as Mike's says I'm only 50 miles away.  Give me a call if you need any help or advice.
Follow AKS tuning on Facebook
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #17 on: April 06, 2012, 10:25:19 pm »
Do you recommend any in leicester at all?
Craig - sorry to hear of the issues.
If you're in Leicester(?), you're nicely based in the Midlands with some good options within 50-70 miles max I would expect.
There are two VAG/Porsche specialists I can recommend my way (Northampton) if you're stuck for a source. Both provide a good service and will be cheaper then Volkswagen direct.
PM me if you're not sorted soon, just up the road really.
Pete
Offline Craigh1983
    • Leicester Wedding Photographers
« Reply #18 on: April 09, 2012, 06:27:55 pm »
OMG what the hell were VW talking about!!!
Just had a mechanic come round to have a look at my car to check out the oil in the spark plugs problem. Well the mechanic took the spark plugs out and there was no oil at all on the spark plugs or in the hole the they sit in!
He also did a compression test and he said the results were perfect and that it sounds like VW were trying to rip me off!
So the problem is just with the injectors, which im getting sorted at mates rates for £50 for the labour and then the cost of the injector itself. Thats a weight off my shoulders!!!
Offline mvb12
  • -Receive: 64
« Reply #19 on: April 09, 2012, 06:43:30 pm »
once fixed get it on vcds (make sure all is clear) then write a strong worded letter to the stealers.
Offline Craigh1983
« Reply #20 on: April 10, 2012, 06:07:40 pm »
Yea i'm definately gonna write to them!
Got the car booked in for Friday to have the injectors sorted but i've just realised I need to get the car down there. I know people say don't drive the car with a misfire, but if I drive very slowly and carefully should it be ok? Its about 6 miles from my house.
Offline beetie
  • -Given: 34
« Reply #21 on: April 10, 2012, 06:36:59 pm »
Which dealer is this, for my reference.
Parkway leicester or Arthur prince loughborough.
Hope it gets sorted :happy2:
Offline AndyED30
  • ED30
« Reply #22 on: April 10, 2012, 09:36:35 pm »
If your not sorted with a GOOD garage yet try APS in Brackley (Northampton area) all ex VW, Audi & Porsche guys and really know their stuff. And I believe they've won the Audi Driver Independent Service provider for England for the last 6 years in a row..............................can't be a bad advert can it  :happy2:
« Last Edit: April 10, 2012, 09:38:09 pm by AndyED30 »
Offline Craigh1983
« Reply #23 on: April 10, 2012, 10:43:29 pm »
[/quote]
I'd love to be able to take it that far but i've been advised not to drive the car at all. Apparently with a misfire I could get fuel into the exhaust and break the cat. So this has become a really difficult situation.
Like an idiot I booked the car in for Friday at a garage 6 miles away but now im thinking hmmm how am I gonna get it there. So im gonna ring em tomorrow and hope that they can collect it somehow.
Offline Craigh1983
« Reply #24 on: April 17, 2012, 09:33:38 pm »
Will this ever get sorted? LOL
Called the garage I got the car from originally and they agreed to do the labour for free as long as I pay for the part as the car is 1 month out of warranty. Took it in last wednesday, called them Friday and they had not even looked at it as they are doing the work inbetween other jobs. Called Monday just gone and was told they have the injector and car will be done Tuesday (Today). Called today and was told they havent done the work and it would be Thursday that the car would be ready. They also said they don't think its the injector and that they want to have a proper look at the car as they think it could even be the air mass sensor or lamber sensor or O Rings?? even though I told them there was a misfire on cylinder 3 and that fault showed on 2 of them computer things that you plug into the car, something that the garage had not even done yet after having my car for 6 days!
So the mechanic has now told me that the car 'should' be done by Thursday. So are labmer sensor, airmass sensor or O rings possible with the problem I have??
I have been without a car now for nearly 2 weeks. Really pi**ed off!
Offline robdf2
« Reply #25 on: April 18, 2012, 01:23:51 pm »
Unfortuanllty mate its how main dealers work.
I had a constant missfire on my car and i complained loads and i mean loads (TFSI Mike knows what i have been through)
Dealers have a set procedure to investigate issues , and will not deviate from it.
even though your injector probably is the issue , i would think that because they are paying the labour , they are probably trying to look at parts they can remove and try easily before getting into the time comsuming things like removing your intake manifold to replace your injector.
Incidently missfires and injector issues on cylinder 3 are very common.
By the way my issue turned out to be the timing being incorrectly set for over 3 years , even though i was told that my car wouldnt even run if the timing was out.
There is a lot to be gained from reading these forums and learning from peoples experiences , and a good independant specialist is worth 10 main dealers any time !
good luck mate keep us posted.
2008 Chrono yellow Cupra
Offline 56OctyVRS
  • -Receive: 72
« Reply #26 on: April 18, 2012, 04:59:17 pm »
If the fault was reported to the garage whilst under the warranty period and the issue has not been fixed. You are not liable for any costs involved in fixing it, as they are still bound to honour the warranty. I would argue with the garage about it.
Offline martziniuk
« Reply #27 on: April 18, 2012, 06:02:18 pm »
I had a cylinder 2 misfire after going K04. After swapping plugs and coils round I bought and fitted a new injector which worked a treat. I think gererally if you swap plugs and coils round and still get the misfire it's often the injector.
Mk2 Octavia vRS with K04 conversion, 3"TBE & Decat, APR HPFP, BDM Intake, S3 I/C, Sachs clutch & Unicorn custom map, S3 brakes, AP coilovers, THS mounts.
B8.5 Audi S4 with uprated pulley and unicorn Stage 2
Offline Craigh1983
« Reply #28 on: April 19, 2012, 05:10:22 pm »
Well yes I did report the fault when under warranty but I assumed it would be the coil packs and I noticed there was a recall on my golf for the coil packs. By the time i got this sorted it was out of warranty. They agreed to do the work for free if I pay for the part but I agreed to it as I didn't want to argue.
I called garage again today and he said he unplugged the air mass meter and the car ran perfect and misfire had gone. So he said that is causing the problem and has ordered one from vw and car will be done tomorrow. The thing is I've looked on multiple forums and everyone says the same and that's it can't be an air mass meter problem if there is a single cylinder misfire! It would be multiple or random.
I really don't know wat to do because I can't really tell him he's wrong. Only thing I can do is pick the car up and test it. I'm gonna make sure I tell them though that if the problem persists I want refunding for the meter as that obviously hasn't fixed the misfire!
And so it bloody continues...
Offline Horatio
  • -Receive: 39
« Reply #29 on: April 19, 2012, 05:23:43 pm »
Stick with it  :happy2: When its running perfectly she'll hit the sweet spot  :driver: :love: Have you tried calling UK VW Customer service for extra advice/help? Worth a call. Hope you get it sorted.
