Author Topic: Battery drain on 2008 gt tdi after RNS 510 installed.  (Read 9136 times)
Offline Craigevs
« on: April 11, 2012, 06:56:43 pm »
Hi, Just purchased  a RNS 510 and iv noticed that i have Battery drain. ( The player has black screen  and runs when off )    Iv been recommended from Edition38.com that there is a guy called EDDIE-NL which could solve the problem.
Any help would be much appreciated  :smiley:
                   Many thanks Craig
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: Battery drain on 2008 gt tdi after RNS 510 installed.
« Reply #1 on: April 11, 2012, 07:14:37 pm »
When was your car made?
Offline Craigevs
« Reply #2 on: April 11, 2012, 07:15:32 pm »
2008, is it a big problem to fix?
Offline bacillus
  • -Receive: 453
« Reply #3 on: April 11, 2012, 07:21:00 pm »
You really need to find out what version gateway you have installed, something you can do with a vcds scan.
If it needs updating then you can get an updated one from Eddie.
http://www.mk5golfgti.co.uk/forum/index.php/topic,40034.0.html
Offline Craigevs
« Reply #4 on: April 11, 2012, 07:27:34 pm »
Sorry to be a pain, What's a Vcds? i really dont know what this stuff is.      Me + electrical issues = disaster  ha  :stupid:
« Reply #5 on: April 11, 2012, 07:49:19 pm »
its a progam on a lap top that reads data of your ecu--through the serial port in your car
Offline Craigevs
« Reply #6 on: April 11, 2012, 10:38:49 pm »
Will i be able to get the info through a vagcom? if so what am i looking for?
Offline bacillus
  • -Receive: 453
« Reply #7 on: April 11, 2012, 10:46:18 pm »
vcds is the new name for vag-com.
And yes, do a scan and post the CAN Gateway (address 19) details.  :smiley:
Offline Craigevs
« Reply #8 on: April 11, 2012, 11:01:49 pm »
Okay ill do that tomorrow. Iv never used this equipment before so are there any sub menus that i need to go into to find the specific info?  Now i keep seeing this member called Eddie-NL that seem to be able to renew the parts ect... When i post this info what happens then?
Sorry for my lack of  electrical automotive  knowledge. I really do appreciate all the help. :)
« Reply #9 on: April 11, 2012, 11:03:59 pm »
Eddie will tell you from the scan what part you need or drop him a pm
Offline Craigevs
« Reply #10 on: April 11, 2012, 11:35:39 pm »
thanks mate ill send him a pm tomorrow once i ( some how ) manage to get this info.
Offline Craigevs
« Reply #11 on: April 12, 2012, 01:14:42 pm »
Iv got my hands on a VCDS iv had a little play and got into the CAN GATEWAY from there what information does Eddie require?
Offline bacillus
  • -Receive: 453
« Reply #12 on: April 12, 2012, 02:22:04 pm »
This is my info for that address:
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 280010630309E0
   Coding: 7F3F0742070003
   Shop #: WSC 01287 785 00200
   VCID: 2A50CF2BFC6F
My gateway version is F
Offline nezquick
« Reply #13 on: April 12, 2012, 02:23:06 pm »
wan't there a battery drain issue with one of the versions of the RNS? i swear i've read something on here about it  :stupid:
Offline boxxer1973
« Reply #14 on: April 12, 2012, 02:27:11 pm »
It's the software that causes the drain. From whet I've gathered it doesn't get the signal from the gateway to turn off
Mk5 golf Gti REVO. stg2+
Milltek | Auto tech | White line | Forge | REVO | KW | Quaife | helix clutch |
