Author Topic: Map lost??............Not yet.  (Read 4154 times)
Offline s3dubbin
« on: April 26, 2012, 09:48:43 am »
Disconnecting the batt/swapping battery? How long do I get before my Revo map is lost, if anything? My stage 4 map is not on my sps yet. Cheers, Stevie.
Re: Map lost??............Not yet.
« Reply #1 on: April 26, 2012, 09:52:57 am »
I think it gets lost as soon as you restart the engine after battery disconnection.
Get it loaded on your SPS box as *backup. Otherwise you'll need to visit a Revo dealer and may need proof of Revo purchase. Some dealers charge a set fee of ~£25.
* EDIT: Read DomT's post below. It's the Boost/Fuel/Timing settings which are stored, not the actual map.
« Last Edit: April 26, 2012, 09:02:46 pm by RedRobin »
Offline s3dubbin
« Reply #2 on: April 26, 2012, 09:57:09 am »
Ok thanks. Was wanting my race battery in for Sunday (also when my map will be stored on sps) and i'm not carrying two batts. Will just wait and leave the big heavy monster in. Cheers!
Offline webby888
« Reply #3 on: April 26, 2012, 08:39:30 pm »
why does disconnecting the battery loose the map?
Offline Poppa Dom
« Reply #4 on: April 26, 2012, 08:57:07 pm »
The SPS does not store the map, it is merely the interface that Revo use to adjust their map. the SPS allows the user to store predefined map settings (boost, timing, fuelling) in addition to switching between Revo stock and performance modes and the anti theft enable/disable. Disconnecting the battery I'll not lose the map, merely revert to Revo stock and need the ps to switch back to the performance map and correct settings.
Offline s3dubbin
« Reply #5 on: April 27, 2012, 09:08:43 am »
I only have stage2+ with my sps not stage4 so i'm screwed until Sunday. What stores the map, the ecu?..........and disconnecting the battery resets the ecu there for map would be lost? Cheers, Stevie.
« Reply #6 on: April 27, 2012, 09:12:11 am »
You can read the settings with a laptop and the SPS. The settings are level of tune independent.
Time to read the instructions.  :wink:
Offline s3dubbin
« Reply #7 on: April 27, 2012, 09:14:30 am »
Nah fuk that dont need instructions not messing about with that. Stevie.
Offline Sammy
« Reply #8 on: April 27, 2012, 11:57:36 am »
IS this the same with all maps? Disconnecting battery deletes map?  :confused:
GTI MK5 with all the gooodies
K04 power going on soon!
« Reply #9 on: April 27, 2012, 12:01:22 pm »
So you can't be arsed to read up about it... but you want peoples help.....  :fighting:
Offline ktlstar
« Reply #10 on: April 27, 2012, 12:03:22 pm »
No it does not delete the map, it just reverts back to basic settings such as B1 T0 F0 IIRC
You'll need the SPS switch to adjust back.
- #1240 ED30 Revo STAGE2+
- Southeast - Vag Com owner
Offline Sammy
« Reply #11 on: April 27, 2012, 12:04:10 pm »
No i meant if your not revo?
« Reply #12 on: April 27, 2012, 12:05:21 pm »
With other maps, disconnecting the batter had no effect.
Offline ktlstar
« Reply #13 on: April 27, 2012, 12:06:16 pm »
what rich said ^^  :innocent:
Offline john87
  • -Receive: 53
« Reply #14 on: April 27, 2012, 12:10:43 pm »
In all cases I'm aware of, disconnecting a battery will NOT erase a performance map from a car. If this was the case, the OEM map would be deleted when your battery goes flat  :grin: as its written on to the ECU in the same fashion...
Disconnecting the battery will merely send any 'self-learn' settings back to their respective datum, i.e. timing advance, etc, until the car is driven a reasonable distance to re-learn these settings. I never had any issues with my mapped civic after removing the battery several times  :happy2:
