Author Topic: Steering a little too heavy  (Read 18612 times)
Offline Sammy
« on: April 30, 2012, 10:20:46 pm »
I came to open this post because I came to realise that my steering feels a bit heavy at car park parking, isn't the gti steering meant to be light at slow speeds and then gt heavier as it picks up speed?
GTI MK5 with all the gooodies
K04 power going on soon!
Offline Kregiel
  • -Given: 28
  • -Receive: 20
  • Supersonic
Re: Steering a little too heavy
« Reply #1 on: April 30, 2012, 10:58:29 pm »
i'd like heavier steering on mine, would get rid of the power steering motor if could!
have you checked air in the tires? It could be something simple as power steering is not prone to failure AFAIK
Paul
« Reply #2 on: April 30, 2012, 11:03:22 pm »
I think you can change the steering with Vagcom???  :confused:
Someone will chime in soon.  :wink:
« Reply #3 on: April 30, 2012, 11:08:05 pm »
Only pre 2006 if i remember right.
Offline Phil Miller
  • -Given: 86
« Reply #4 on: April 30, 2012, 11:09:09 pm »
Yes you can, there is a page in the ross tech wiki
here you go depends on age of car by the sounds of it
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist
2004 Golf 5dr TDI, 140 remap, GTI front bumper, skirts, highline cluster, 18in wheels, jamax coilovers, winter pack
WANTED HIGHLINE CCM AND CECM PLEASE PM ME IF YOU CAN HELP
Offline Sammy
« Reply #5 on: April 30, 2012, 11:09:16 pm »
What can I change with vagcom and how?
Offline Phil Miller
  • -Given: 86
« Reply #6 on: April 30, 2012, 11:10:03 pm »
see above mate
Offline Sammy
« Reply #7 on: April 30, 2012, 11:14:39 pm »
Am confused on what needs to be done still?
« Reply #8 on: April 30, 2012, 11:16:40 pm »
Well it sounds like you won't know what to do with vagcom, but if you find someone that does, tell them your steering is a bit heavy and that you would like it setting to a lighter setting.  :happy2:
« Reply #9 on: April 30, 2012, 11:19:12 pm »
From Rosstech…….
"Generation 1 and early Generation 2 still allowed switching between up to 16 different predefined Characteristic Curves, while later/updated Generation 2 and 3 do not and the Adaptation Channel is being inactive/unavailable."
What year is your Gti?
Offline Sammy
« Reply #10 on: May 01, 2012, 12:31:50 am »
Mine is 2005 but how do i know what gen i have?
« Reply #11 on: May 01, 2012, 12:45:14 am »
Gen 1  :happy2:
Offline john87
  • -Receive: 53
« Reply #12 on: May 01, 2012, 09:50:57 am »
My steering felt heavier when I switched from the standard 17's (with winter tyres) to Monza 2's with summer tyres. Definitely affected by tyre pressure though, and road surface... I find the steering is perfectly weighted in my GTI compared to the 'arcade game' light setup in the courtesy Polo I had a few months ago  :happy2:
vw55raz
« Reply #13 on: May 01, 2012, 10:09:34 am »
In vagcom there's an option to select how stiff or light you want the steering to be. But as mentioned above, depends which year your golf is.
« Reply #14 on: May 01, 2012, 10:57:55 am »
I'd definitely start off  with checking the tyre pressures before fiddling around with settings. Check your fuel filler cap for the right pressures.
