Author Topic: Battery drain query - should but don't!!  (Read 1563 times)
Offline johnhol78
« on: May 06, 2012, 08:48:29 pm »
I have a 55 GTi with an L gateway (i think)
But I installed a RCD310 and don;t get battery drain (had for months now)
So would installing a RCD510 cause any problems over the 310?
vw55raz
Re: Battery drain query - should but don't!!
« Reply #1 on: May 06, 2012, 10:43:10 pm »
L gateways are fine. Some K gateways work. Anything under a K will drain battery so you should be ok. But as its a 55 plate I would double check which one u have. Mine was an E
Offline johnhol78
« Reply #2 on: May 06, 2012, 10:52:52 pm »
Yeah, will double check though with no battery drain on an RCD310 there shouldn;t be on a 510...should there?
