Author Topic: Upgrade DV!!??  (Read 17164 times)
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Upgrade DV!!??
« Reply #15 on: May 17, 2012, 03:10:30 pm »
Moz managed to get one lol
i have one, i didn't think it was worth anything tho so i was gonna bin it bbut someone can have it for postage cost plus £5 that i'll donate to the forum
Edit: mine's a B revision. Not sure what the difference is between them
« Last Edit: May 17, 2012, 03:12:07 pm by sub39h »
PLANS: Stage 2+
Offline ianv5
Re: Upgrade DV!!??
« Reply #16 on: May 17, 2012, 03:17:10 pm »
Got my 'G' off ebay last night (so it is used but I have been assured it is in full working order!)
Re: Upgrade DV!!??
« Reply #17 on: May 17, 2012, 03:28:35 pm »
I have a revision c that came off my car after 2k miles. ideal for standard or stage1 if struggling to find a revG
Offline Tamiyoman
  • -Receive: 39
Re: Upgrade DV!!??
« Reply #18 on: May 17, 2012, 05:28:49 pm »
Any thoughts as to where you can get the G as apparently they aren't manufactured any more??
Jabbasport got mine in for me, I am assuming they got it from TPS or VW.
Offline Moz
Re: Upgrade DV!!??
« Reply #19 on: May 17, 2012, 06:28:06 pm »
Going to give this a go on Sunday! Hopefully should make a difference.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
Re: Upgrade DV!!??
« Reply #20 on: May 17, 2012, 06:59:00 pm »
Keep looking on the forum for a G!
FYI - the rev D ISN'T FROM THE TFSI - it's actually from the TSI engine(so probably is newer than the TFSI rev G)
Offline ianv5
Re: Upgrade DV!!??
« Reply #21 on: May 17, 2012, 08:18:31 pm »
Took my 'B' version out this evening, has probably been on the car since 2005 as I am going to replace with 'G' version I bought last night.
Glad I did nice little rip:
No fault lights in car and as far as I knew car was running ok.
This picture shows black areas where rubber is breaking down and about to split:
Offline Shabba168
Re: Upgrade DV!!??
« Reply #22 on: May 17, 2012, 08:32:47 pm »
Go forge and dont worry again
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
Re: Upgrade DV!!??
« Reply #23 on: May 17, 2012, 08:39:11 pm »
Other companies use valves simlar to these the Citroen DS3 1.6T has one that looks identical. and with a nice thick yellow rubber.  I am going borrow one from him.
R-Tech Performance Tuning & Rolling Road Centre
Custom ECU Remap Tuning Specialists
1.8T - 1.9TDI - 2.0TFSI - 2.0TDI - DSG
Hinckley Leicestershire LE10 3BY
01455 617233
We aim to be the best not the biggest!!
8AD1691 - 1000101011010001011010010001 - 8AD1691
www.sticky-vnt.co.uk www.removal-dpf.co.uk
Type_R
Re: Upgrade DV!!??
« Reply #24 on: May 17, 2012, 08:41:07 pm »
My G revision lasted the best part of 1 week after my stage 1 remap by Jabba, before it let go - engine warning light and turbo limp!!
Changed it to a D revision from Awesome, and has been fine since! I would never go back to a diaphragm type! Best to go Forge IMO!
EDIT - I might be confused, basically the diaphragm type which came on the car (2005) lasted a week after the remap. The piston type is still going strong!
« Last Edit: May 17, 2012, 08:56:00 pm by Type_R »
Re: Upgrade DV!!??
« Reply #25 on: May 17, 2012, 08:44:36 pm »
Had a G on since i sold my forge before x mas. no issues yet touch wood
Offline ukdub
Re: Upgrade DV!!??
« Reply #26 on: May 17, 2012, 08:47:41 pm »
My revision 'D' valve lasted just over 12 months.  It looks fine but it will not hold over 16 psi.  Presently punishing my old 'B' valve at up to 24psi  :happy2:
Laser Blue with K04 power, APR hardware controlled by REVO 2+ software
Chassis by KW V3's, Whiteline and a hint of PRO race 1.2's
Brakes by Brembo 4 pots
Offline R-tech-Nick
  • -Receive: 30
Re: Upgrade DV!!??
« Reply #27 on: May 18, 2012, 08:57:41 am »
At end of day A B C D E F G H I J K  ect.... are all going to fail at some point,  early ones quicker than the newer ones with tuned engines.   Just have a look at D valve and pull it apart you will see.
D valves dont break like the rubber desgins, but they are crap at the job the are meant to do.  The G valve seals very well but at end of the day its still a rubber version which could end up splitting.
The way I look at it is if the G valves last 2-3year and only cost £40 then in my eyes thats a good investement to keep changing it if it fails.
01455 617233
Re: Upgrade DV!!??
« Reply #28 on: May 18, 2012, 09:15:18 am »
.... And that's why I've got a spare rev. G in the shed :-)))
Offline ianv5
Re: Upgrade DV!!??
« Reply #29 on: May 18, 2012, 09:27:20 am »
Totally agree :happy2:
The only concern I have is as far as I knew my car was running fine (no warning lights, car seemed to be pulling nicely, mpg was good) even though my 'B' version had split!
What should I be looking out for so I know when to change it next time?
 I only removed mine because I had seen no evidence of it ever being changed car is a 2005 Model Gti. Luckily I have a 'G' version on its way.  Should I always have a spare just in case?
« Last Edit: May 18, 2012, 09:29:18 am by ianv5 »
