Author Topic: Seat belt alarm issue...anyone help  (Read 15706 times)
Saintsteve
« on: May 28, 2012, 09:13:59 am »
For some reason, when I have a passenger in the front, I intermittently get the fasten your seltbelt alarm go off and it's driving me nuts!!!! .
I've looked on Vcds to see if I can find the controller but can't see where it would be, also where should I be looking where this plugs into the Seat if it's a loose connection??.
I know the wife has lost 4 stone recently , but it's not enough I'm sure to think she's that light lol
Thankyou  :drinking:
Offline Jussa
  • Bicester
Re: Seat belt alarm issue...anyone help
« Reply #1 on: May 28, 2012, 09:19:38 am »
Does the alarm go off even when the bel is plugged in??  :confused:
I know that the alarm can be removed totally thru VCDS as my mate I'd I for me on my old GTi
Offline ktlstar
« Reply #2 on: May 28, 2012, 09:22:37 am »
You have to manually enter the +2 for seatbelt chime in "instruments and then coding"
You'll understand what i mean when your in VCDS.
- #1240 ED30 Revo STAGE2+
- Southeast - Vag Com owner
« Reply #3 on: May 28, 2012, 09:22:59 am »
Thankyou  :drinking:
As above steve... just disable the beeping in VCDS.  :happy2:
Saintsteve
« Reply #4 on: May 28, 2012, 09:24:03 am »
Yes, both seat belts fastened, just like your driving along and decide to unplug it .. Bing ..bing ...bing ...bing bing ...bing lol
It's annoying as hell!! Only does it for about. 3 or 4 seconds and stops. Normally have to ask the passenger to move in the seat to stop it?
« Reply #5 on: May 28, 2012, 09:25:13 am »
Disabled mine in vcds but can't remember which module it was in.  Didn't take long to find.  Central electronics or convenience.
Are you daaaan saaarf Steve?  If youre passing Nottingham at any point I could have a look
Saintsteve
« Reply #6 on: May 28, 2012, 09:25:36 am »
I will try the above, thankyou KTLSTAR  :happy2:
Saintsteve
« Reply #7 on: May 28, 2012, 09:26:45 am »
Any further south and I'd be in the English channel.  :sad1:
« Reply #8 on: May 28, 2012, 09:28:39 am »
So what ever your first 2 number are, 07 for example. -02.... so 07 becomes 05. Or 23 becomes 21.
Offline bacillus
  • -Receive: 453
« Reply #9 on: May 28, 2012, 09:35:02 am »
I think your first coding is correct if you look at where the ?? are in the long coding helper.
Saintsteve
« Reply #10 on: May 28, 2012, 09:42:26 am »
So my numbers are 0003403... So which value do I minus 2 off?
« Reply #11 on: May 28, 2012, 09:50:00 am »
Are you looking in the right place? It should only be 5 digits
Saintsteve
« Reply #12 on: May 28, 2012, 09:51:47 am »
Where your 07232 number is, is where my 0003403 is??
My nav unit +16 for some reason doesn't list like yours though rich? Mine isn't there.. Although I have a RNS installed
Offline Shabba168
« Reply #13 on: May 28, 2012, 10:08:31 am »
Disconnect the 2 pin plug under plastic cover under seat
Job done
« Reply #14 on: May 28, 2012, 10:11:45 am »
Thats nit mine steve, just an image i pulled of the net.
