Author Topic: Is stage2 ko3 worth it?!?!  (Read 4325 times)
Offline nezquick
Re: Is stage2 ko3 worth it?!?!
« Reply #15 on: June 07, 2012, 11:46:49 am »
Yup - ran a rev G went to a D more for the sake of going to a D - only thing I noticed was the G made a louder (better) whoosh noise compared to the piston.
Offline gigolo456
« Reply #16 on: June 07, 2012, 11:49:06 am »
well having a Twintake fitted, so im sure there will be plenty of whooshing alright!! Can i ask plse if you noticed anything else that was different between the 2, eg. performance wise, smoothness, etc?
Offline blackmagic
« Reply #17 on: June 07, 2012, 08:43:06 pm »
Def worth it! One step closer to stage2+  :smiley:
Although I did it slightly differently. Stage 1 then added pump. Ran this config for a while then fitted tbe and got stage2+ map done at same time.
Black GTI K03 Revo Stage 2+,
Offline Dan.b
« Reply #18 on: June 07, 2012, 08:48:02 pm »
What kind of power are you stage 2+ boys running?
Offline Sie
« Reply #19 on: June 07, 2012, 09:06:01 pm »
£600 Apr or £275 Autotech (Internals only and get them fitted by a garage)
Where from? Cheapest I have found is about £670 plus vat. Even if you send your pump away it's still £500 inc vat.
Fettled Laser Blue '05 GTi 5dr
