Author Topic: Reg plate surround  (Read 1527 times)
Offline nathangallo
Reg plate surround
« on: June 27, 2012, 06:08:39 pm »
How do you take the reg plate surround off on the front??
Thanks  :driver:
Offline dan1985
    • Durham Collective
Re: Reg plate surround
« Reply #1 on: June 27, 2012, 07:09:57 pm »
Take plate off and locate the plastic rivnuts holding plinth to bumper. Either push the plastic circular centres through and out the other side or just use a drill. Then give it a pull and it'll be off
www.durhamcollective.co.uk
North East VAG Owners Club
Offline apples12
« Reply #2 on: June 27, 2012, 09:34:09 pm »
once you unscrew your numper you'll see the four push pin rivets if its been fixed on properly
Google for 'Push Pin Rivet' and go to images - once you've got an idea of what your dealing with it'll be much easier - dont take a drill to it - thats overkill for a few tiny plastic push rivets!
you'll notice theres four 'notches' around the circle
use something thin, rigid and flat to get into those notches and pry out the centre flat 'pin', it should eventually come out totally (that centre pin goes into the other round bit which goes through the plinth and bumper and 'spreads' them to hold them in)
then do the same to all four corners
then very carefully pry out the centre pieces too
then it'll just pop off
be careful not let the numper plate plinth swing down on one pin as you may scratch your bumper...ask me how i know!
MK6 GT TDI  - CW - LUX pack
GONE
MkV Golf 1.9TDI Sport in DBP, 160,000 miles and climbing!
Retrofits by me:GT front end,OEM bixenons with auto-levelling/washers, Valeo LED Rears, MFSW + Highline SWCM, Cruise Control, 30byte Highline CECM, Highline clocks, Rain/Light Sensor, Auto-dimming Rear view Mirror, RNS-510 LED (Ver H; SW: 4020), Fiscon Basic Bluetooth, MDI + Aux, Armrest, Reverse Camera LOW, TPMS..what next...
Offline nathangallo
« Reply #3 on: June 27, 2012, 10:07:06 pm »
Thanks guys!
Ahah don't sound good with the scratching! :signLOL:
Offline Kalpsn2000
  • -Receive: 56
« Reply #4 on: June 28, 2012, 03:07:09 pm »
I would have thought it would be much easier, and probabaly safer, to remove by first taking the grill off the car then pushing the pins out from the rear?
