Author Topic: Quick question, VAG COM  (Read 1811 times)
Offline brown-1234
« on: July 30, 2012, 10:42:14 pm »
Hi all
Another quick question, i remember when i had my MK4 that i went to someone who had VAG COM and he enabled loads of cool mod's for my car. I was just wondering if there is any for the MK5 ? and if you's could recommend any. I live in the northeast and am prepared to travel if someone on this forum offers this service.. Any help would be great..
Thanks  :happy2:
Offline edd666999
  • -Receive: 89
Re: Quick question, VAG COM
« Reply #1 on: July 30, 2012, 10:47:24 pm »
auto lock after 15mph
beep on lock unlock
auto window close on holding the lock key
only open drivers door on unlock
im sure there's loads, most similar to the mk4
Offline brown-1234
« Reply #2 on: July 30, 2012, 10:49:16 pm »
Ah cool, is there one for when you unlock the lights come on ? And stay on for 30 secs after locking ? Thanks
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #3 on: July 30, 2012, 10:50:52 pm »
There are loads (including coming home/leaving home lights you have asked about) but what is there depends on what year the car is and what revision CECM & CCM you have.
Where in the Northeast are you as I'm near Darlington.
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #4 on: July 30, 2012, 10:52:00 pm »
Comming Home and Leaving Home it is
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline brown-1234
« Reply #5 on: July 30, 2012, 10:54:07 pm »
Im just from durham mate, is it easy to check what i can get or do i need VAG COM need to find that out.
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #6 on: July 30, 2012, 10:56:47 pm »
You need VCDS (new version of Vag-Com) to find out. Either that or strip your dash to see what part no. is on the CECM & CCM :laugh:
Your more than welcome to come to me at some point and I can take a look and enable whatever can be for you.  :happy2:
Offline brown-1234
« Reply #7 on: July 30, 2012, 10:59:15 pm »
Ah that would be great, ill pm you!
Offline Baz300
« Reply #8 on: July 31, 2012, 03:13:41 pm »
I can set the lock above 15mph and coming home lights on my mfd with the steering wheel controls.
And the window open and close with the fob works too
