September 27, 2026, 06:18:56 pm
All Things Mk5
Mk5 General Area
Topic: 1 (Read 1961 times)
Beattie
Always Involved
-Given: 2
-Receive: 4
August 07, 2012, 06:25:56 pm »
Last Edit: September 24, 2012, 09:05:14 am by CraigDavieBeattie
MK6 2.0 GT Tornado Red.
JoeDarKa
Just look at my post count
-Given: 57
-Receive: 74
Re: Steering wheel rubbing...?
Reply #1 on:
August 07, 2012, 06:58:22 pm »
Is it not the steering wheel itself? When i swapped mine over, it was catching / squeaking where it hit the steering collumn. I just put up with it until I changed it again for a flat bottom one
GT Sport - Reflex Silver 2.0 TDI
My Build
JoeDarKa
-Given: 57
-Receive: 74
Reply #2 on:
August 07, 2012, 07:14:14 pm »
I dont think there are any differences. My wheel looked like it was tipped backwards slightly so was catching the top of the collumn
My Build
JoeDarKa
-Given: 57
-Receive: 74
Reply #3 on:
August 07, 2012, 07:19:38 pm »
I didnt, I just put up with it until i changed wheels again unfortunately
My Build
Eddie-NL
Trader - 2014
-Given: 0
-Receive: 298
My Ride:
Re: I changed my steering wheel from standard to ED30 and now its squeaking??
Reply #4 on:
August 09, 2012, 07:09:55 am »
I'm sure that if you take the wheel off and the trim. And make sure that the trim is as far forward as it will go should sort it
Genuine VCDS VAG-COM HEX-USB + Genuine Vag Commander + Genuine VAG Tacho + Genuine VAG CAN PRO + RNS Manager for Video in Motion and New Pin Code for RNS510
Cluster and Key coding
Location Great Yarmouth
john87
Won't Shut up.
-Given: 11
-Receive: 53
Reply #5 on:
August 09, 2012, 12:07:03 pm »
This happened with my first car (corsa) when I changed the wheel... it was the slip ring that was causing the squeak. It eventually stopped once the contacts got dirty enough
JoeDarKa
-Given: 57
-Receive: 74
Reply #6 on:
August 10, 2012, 09:49:53 pm »
Glad you have sorted it!
My Build
Andy
Admin
-Given: 39
-Receive: 447
Reply #7 on:
August 10, 2012, 09:54:43 pm »
you can turn your radio back down now
gttdi build thread
r32 build thread
All Things Mk5
Mk5 General Area
