Author Topic: Can xenons be retro fitted from another golf?  (Read 8133 times)
Re: Can xenons be retro fitted from another golf?
« Reply #15 on: August 11, 2009, 05:36:54 pm »
Nope they wont be legal but the beam pattern is fine.
you can change the beam pattern from LHD to RHD quite easily IIRC too.
The flick up changes from left (rhd) to the right (LHD)
Offline ollie288
« Reply #16 on: August 25, 2009, 06:26:40 pm »
Do you know if it cuts the beam or it actually converts it JPC? :happy2:
Offline Oli
  • -Given: 19
« Reply #17 on: November 05, 2009, 04:20:26 pm »
Right, rather than open a new thread, I thought I would add to this.  I have a donor car, that I can have the xenons off.  However I will have to convert this back to normal lights.  SO I have to swap both ways.  I will source a standard set of lights(ie not GTI) for the donar car.  I know I need leads from kuftec, but how easy is it to take the levellers etc, is all the wiring there already?  And how easy to convert the GT back to standard lights?
ANy help much appreciated, and I just want to know if its worth the bother!
Offline mortygttdi
  • -Receive: 146
« Reply #18 on: November 05, 2009, 04:59:04 pm »
Oli it would be far easier to take the levelling sensors and control box off and buy the loom from Kufatec,
For the simple reason the wiring will be very hard to trace back from the sensors and control box you could also take the washers off aswell and again buy the loom which is 40 euro's from kufatec.
If you do it get an how 2 up for the rest of the forum,  although there is some excellent write ups on the net for all this.
Darren
Offline T30GUE
« Reply #19 on: November 11, 2009, 10:21:24 pm »
If you have a doner car, can't you use the same Xenon leads? Why do you need the Kuftec ones?
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #20 on: November 11, 2009, 10:26:57 pm »
^ x2.
Or... Can the leads be purchased from VAG perhaps?
Pete
« Reply #21 on: November 12, 2009, 10:54:00 am »
there arent any "leads" on a car fitted with xenons from the factory.
There is a 12 pin plug for the xenons connected to a massive loom that would just be a nightmare to take out.
On a halogen car, there is a 10pin plug. The plug is a different shape.
you NEED to get the Kufatec Looms, or you can make your own, but it would a lot easier to buy the kufatec looms
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #22 on: November 12, 2009, 11:19:24 am »
The hardest part would be to get the Xenon Car to Halogen.
Hope this helps
Offline marko
« Reply #23 on: October 21, 2012, 10:01:20 pm »
bit of a thread revival......
has anyone here ever added the auto shutter option to the xenons on a midline cecm???
i have a gt model which i think hasnt got a highline cecm but i want the high beam xenon to work....
2007 TR gt170...heated leather,underseat drawers,auto-levelling bi-xenons,puddle leds,chrome switches,footwell lights f+r,cruise control and ed30 rear lamps,LED interior....carbon highline clocks,ed30 front spoiler,RNS 510 P+MDI,mk6 gti gearknob,TPMS done,complete r32 trim kit+ MFSW,r32 f+r brakes,RLS fitted.headlamp washers,folding mirrors and boot pop,mk6 RVC,19"Helios,AP coilies,valeo LEDs  ...dpf delete and remap to finish off
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #24 on: October 21, 2012, 10:06:54 pm »
do you have front fogs?
Cluster and Key coding
Location Great Yarmouth
Offline marko
« Reply #25 on: October 21, 2012, 10:16:23 pm »
yes i do eddy??
standard fit
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #26 on: October 21, 2012, 10:19:48 pm »
you then have a high version cecm
Offline marko
« Reply #27 on: October 21, 2012, 10:31:40 pm »
legend...thanks for great info eddy!!!
