Author Topic: A strange thing just happened, wonder if anyone has any ideas  (Read 3488 times)
Offline waynos
« on: August 23, 2012, 07:08:19 pm »
Driving home from work. M25 was screwed so i went via dorking. Thank god i did, i was sitting in traffic and went to set off when it sarted moving but it turned out the car had stalled. Went to restart and the starter didnt want to turn as if the battery was flat.gave it a couple more tries and then let the car roll on to the grass verge.  Called the mrs to see if she could get me... After i hung up i gave it another go and it started up as normal!? There was a wierd whining noise for a couple seconds then it stopped.
Any ideas on what the hell just happened?
Offline jameelno1
  • TDI Power
Re: A strange thing just happened, wonder if anyone has any ideas
« Reply #1 on: August 23, 2012, 08:07:19 pm »
hard too tell could be anything. was there any smoke coming from the exhaust by any chance?
golf mk5 1.9 tdi
Offline waynos
« Reply #2 on: August 24, 2012, 06:27:37 am »
Nah there wasnt any smoke or anything like that
Offline Horatio
  • -Receive: 39
« Reply #3 on: August 24, 2012, 07:23:25 am »
Had something very similar when I had my gti. Turned out to be the fuel sensor. Also the exhaust emissions light came on.
« Reply #4 on: August 24, 2012, 08:25:51 am »
Failed coilpack?
You don't say what car your problem is on.
Offline waynos
« Reply #5 on: August 24, 2012, 08:40:30 am »
Ah my bad. Its a 2005 gti. Engine managment light is now on! Damn it. If theres anyone in surrey area who could do me a scan id be most grateful
« Reply #6 on: August 24, 2012, 09:11:05 am »
I ask because now we know it's a 2005 GTI there's an increased liklihood it could be a failed coilpack and you should know that you can get them replaced free of charge by VW if they are older than a particular version. That's assuming your car hasn't already had them updated.
There's a thread about it if you want to do a Search.
« Reply #7 on: August 24, 2012, 02:32:36 pm »
Thanks for the Thank You, mate  :drinking:
Do post to let us know what you discovered your problem was when you know. Hope it gets resolved soon.
Offline keano
  • -Given: 79
« Reply #8 on: August 24, 2012, 06:25:49 pm »
Sounds like the low pressure fuel sensor. Get it checked on vagcom. It's intermittent and does get worse, so get it checked out :)
It used to stall my DSG all the time :scared:
Offline Neiltdi
  • Full Hex+CAN
« Reply #9 on: August 24, 2012, 06:40:48 pm »
Where abouts in surry are you bud ?
Full Hex+CAN in Hampshire.
