Author Topic: Fuel setting???  (Read 2806 times)
Offline morry_ed30
Fuel setting???
« on: August 24, 2012, 08:55:50 pm »
Hi guys just a quick one, fuel settings? Is setting 1 leaner with 9 being rich or is it the other way round, got some blue smoke at full throttle and would like to go a touch leaner then data log just unsure which way to go with the setting, higher or lower ?  Thanks in advance  :grin: :happy2:
Offline cupra_k1
Re: Fuel setting???
« Reply #1 on: August 24, 2012, 09:09:34 pm »
Higher is leaner, lower is richer buddy.  :happy2:
Offline chris s
Re: Fuel setting???
« Reply #2 on: August 31, 2012, 08:31:35 pm »
I think its the other way around, high is rich. Most people leave it high to protect the cylinders from over heating with it burning lean
Candy White Edition 30 DSG
Revo Stage 2+
ITG, BCS TBE, Autotech HPFP
WALK
R32 Brake upgrade
S3 IC upgrade
Offline robern2
Re: Fuel setting???
« Reply #3 on: August 31, 2012, 08:59:06 pm »
The higher the number, the leaner the fuel.
Offline chris s
Re: Fuel setting???
« Reply #4 on: August 31, 2012, 09:04:11 pm »
Ok, but i am still not sure about that. Why would revo recommend a lean setting as default
Revo Stage 2+
WALK
R32 Brake upgrade
S3 IC upgrade
Offline Robo
Re: Fuel setting???
« Reply #5 on: August 31, 2012, 09:12:42 pm »
Higher is richer that's why Revo recommend 9 as default on cars without uprated hpfp.
Re: Fuel setting???
« Reply #6 on: August 31, 2012, 09:19:30 pm »
No it isn't. You can still change fuel on a car without a pump.
Offline Robo
Re: Fuel setting???
« Reply #7 on: September 01, 2012, 09:15:31 am »
That's what Revo told me as the standard HPFP is on its limit at stage 2 so requesting maximum fuel was advised
Offline PDT
  • -Receive: 142
Re: Fuel setting???
« Reply #8 on: September 01, 2012, 04:51:24 pm »
The lower the number on Revo setting = more fuel.  :signLOL:
So fuel 9 is leaner than fuel 3
