Author Topic: Vibratechnics lower engine mount  (Read 16365 times)
Offline sub39h
  • -Given: 189
  • -Receive: 84
« on: August 27, 2012, 09:25:53 am »
WHY
As time goes on, the OEM engine mounts perish. This allows engine movement during acceleration. Any energy that is spent moving the engine in the engine bay is energy that isn't used by the front wheels i.e. wasted.
Additionally, aftermarket down pipes (particularly with inadequate or short flexi pipes) may fail under this excessive engine movement.
The front subframe has to be dropped for fitting, so a realignment afterwards is strongly advised. As I wanted to have my car aligned anyway, I felt it was the perfect time to get the mount installed.
SOURCING
Our very own vRSAlex of AKS Tuning is a supplier, and is the cheapest I found.
FITTING
Of course, another job for vRSAlex. Takes 1 hour, and he is able to provide the alignment as well. (He has set my car up beautifully. It feels like a totally different car.)
OTHER VERSIONS
THS
VWR
BlackForest Industries
ECS
PLUS POINTS
Subjectively the car feels much more taut and firm and the engine feels a little torquier (although I did have a larger intercooler and some less ristrictive pipework fitted at the same time which could explain the torque.)
MINUS POINTS
At idle, particularly when cold, there is definitely increased NVH in the cabin. It feels a bit like a rough diesel. Certainly nothing unbearable. When it's warmed up and when you're cruising, it's completely unnoticeable. I've been told it'll take a couple of weeks to bed in so I'm hoping that NVH at idle will soften slightly
SUMMARY
There are cheaper options out there, but Vibratechnics are more robust than these. vRSAlex mentions that THS mounts may wear over time, but the Vibratechnics are will outlive the life of the car.
The upper mounts are quote pricey, but definitely something I'll look to do when I have the money. Overall it's a thumbs up from me thus far.
« Last Edit: August 27, 2012, 09:27:34 pm by sub39h »
PLANS: Stage 2+
Offline chungster
Re: Vibratechnics lower engine mount
« Reply #1 on: August 27, 2012, 10:13:01 am »
Had this fitted a few months ago by JKM - certainly seems to have reduced the wheel hop phenomenon
Managed to pick up the other 2 mounts on the cheap (used and VWR versions) but they're same as VT anyway!
Will hopefully be getting AKS to fit them soon!
Offline vRSAlex
  • -Receive: 253
« Reply #2 on: August 27, 2012, 12:35:09 pm »
Just the one hour for the fitting on the mount  :happy2:
By far the best mount out there.  A lot less vibration than other versions I've fitted and owned in the past.
Follow AKS tuning on Facebook
Offline chungster
« Reply #3 on: August 27, 2012, 03:36:33 pm »
Cheers Alex. Might need you to get hold of the Ferodos for me too!
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #4 on: August 27, 2012, 09:27:18 pm »
oops i got the price of the mount and the fitting cost mixed up didn't i?
changed  :happy2:
PLANS: Stage 2+
Offline dan1985
    • Durham Collective
« Reply #5 on: August 28, 2012, 07:24:11 am »
Are you able to do group buys on the mounts Alex?
I'm after a set for my mk4 R32. Best price I've found for full set of fast road mounts is just shy of £500
www.durhamcollective.co.uk
North East VAG Owners Club
wauler43
« Reply #6 on: September 02, 2012, 05:00:56 pm »
Hi guys new to the site and going through the posts on the lower mount topics, you may be interested that VWR are now supplying a totally different lower mount not made by vibra technics i have tried both and found some difference with the new ones ( i have tried both ) the main things from my experience is the ease of fitment, build quality, slightly firmer without increased vibration even on my DSG car oh and they are a nice blue colour.
It might be worth talking to matty at vwr if you are looking for a group buy ive always found him helpful.
Hope this helps
Offline vRSAlex
  • -Receive: 253
« Reply #7 on: September 02, 2012, 07:57:01 pm »
Hope this helps
Just give kpm a call and ask how long the new VWR mount lasts!  Then you will switch back to the vt mount quite quickly.
wauler43
« Reply #8 on: September 02, 2012, 08:28:19 pm »
are you talking about the latest blue version or the black ones, ive had no problems with either.
« Reply #9 on: September 02, 2012, 08:46:57 pm »
No problems whatsoever with my 'VWR' lower engine mount - The earlier version black one.
Offline vRSAlex
  • -Receive: 253
« Reply #10 on: September 02, 2012, 09:20:21 pm »
The latest blue ones.
Only what I have been informed, but they fall apart.
The vt 'black' mounts are spot on and I've seen ones over 3 years old that are still going strong.
Offline s3kel
« Reply #11 on: September 02, 2012, 11:08:28 pm »
Hi alex could you pm me a price for this for the audi s3 8p3 ,cheers
« Reply #12 on: September 15, 2012, 10:13:28 pm »
I think it's a good idea to replace all 3 engine mounts rather than just the lower engine mount. This is to achieve an even balance and spread the loads/stresses.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #13 on: September 15, 2012, 10:16:06 pm »
I agree - but with all the other work I was having done by Alex that weekend I was severely short on funds and could only afford the lower engine mount. Additionally, as I was getting an alignment done it was the most sensible one to change.
Alex informs me that the lower mount is the one that will make the greatest difference, and whilst I intend on getting the others changed when I can afford it, he mentions it's not imperative to do so right away.
PLANS: Stage 2+
« Reply #14 on: September 15, 2012, 10:24:11 pm »
....I did exactly the same as you and had the other two mounts done later (just a few weeks later).
It's all in my Review: http://www.mk5golfgti.co.uk/forum/index.php/topic,5082.0.html
I also agree with Alex  :happy2:
