June 19, 2026, 06:18:55 am
All Things Mk5
Cosmetic/Interior Modifications
New seats
Topic: New seats (Read 4646 times)
JoeDarKa
Just look at my post count
-Given: 57
-Receive: 74
New seats
September 01, 2012, 02:28:35 pm »
Iv seen some seats a quite like, aftermarket ones as OEM are mega bucks! My current are heated, electric with airbags. If I fit the new seats that are not electric, heated or have airbags (
) how would i get rid of the warning lights e.g. airbag faults? Is it even possible? Cheers all
GT Sport - Reflex Silver 2.0 TDI
My Build
JoeDarKa
-Given: 57
-Receive: 74
Re: New seats
Reply #1 on:
September 04, 2012, 10:48:00 am »
Anyone?
My Build
chrisr763
-Given: 0
-Receive: 62
Re: New seats
Reply #2 on:
September 07, 2012, 01:52:50 pm »
VAG COM. error warning lights can be removed. Many people on here have it, or a second hand could set you back 200-300 ish, perhaps more. But nevertheless a good system to have for your car
JoeDarKa
-Given: 57
-Receive: 74
Re: New seats
Reply #3 on:
September 07, 2012, 02:56:32 pm »
I have VCDS, just didnt know it was that simple!
My Build
chrisr763
-Given: 0
-Receive: 62
Re: New seats
Reply #4 on:
September 07, 2012, 03:29:17 pm »
Ha! Yeah. Airbag faults pop up when the steering wheel and stuff is removed when the key is turned in the ignition. How come your planning to remove comfort!?
what you replacing the seats with
Another tip that might not throw up the errors in the first place. disconnect the battery.... once installed reconnect. Just a punt but might save some hasstle
Eddie-NL
Trader - 2014
-Given: 0
-Receive: 298
My Ride:
Re: New seats
Reply #5 on:
September 07, 2012, 03:35:02 pm »
If you fit seats that are not like your old ones
You will need to code out the seat heating and remove the fuses for the heating
for the airbag, you can code it so the car knows it doesn't have seat airbag, but everytime the ignition is switched on it will pop up with a message seat airbag disabled.
The other option is this
http://www.r32oc.com/topic/39327-mk5-airbag-resistors-recaro-seats/
Genuine VCDS VAG-COM HEX-USB + Genuine Vag Commander + Genuine VAG Tacho + Genuine VAG CAN PRO + RNS Manager for Video in Motion and New Pin Code for RNS510
Cluster and Key coding
Location Great Yarmouth
chrisr763
-Given: 0
-Receive: 62
Re: New seats
Reply #6 on:
September 07, 2012, 03:38:03 pm »
Hooray for geniouses
JoeDarKa
-Given: 57
-Receive: 74
Re: New seats
Reply #7 on:
September 07, 2012, 04:04:22 pm »
Nice one guys!
My Build
higher1
Always Involved
-Given: 8
-Receive: 13
Re: New seats
Reply #8 on:
September 10, 2012, 11:14:48 pm »
Ive fitted oem recaro buckets and carried out the resistor trick it works a treat
Ah-exclusive custom ultra low H&R Coilovers 110mm, ITG induction kit, 18" super RS's, USA rear bumper, USA front grille with smooth number plate surround,recaro bucket seats. now sold !
mk1 golf 1.8 20v turbo
JoeDarKa
-Given: 57
-Receive: 74
Re: New seats
Reply #9 on:
September 27, 2012, 08:35:12 pm »
Do 2 front seats fit in the rear of a 3 door? Im planning on reclining them as much as possible and sit them on their bases?
My Build
JoeDarKa
-Given: 57
-Receive: 74
Re: New seats
Reply #10 on:
September 30, 2012, 04:59:47 pm »
So iv picked my new seats up. They are OEM and not aftermarkets which is good. The plugs connected look like this...
Drivers side
Passengers Side
And my current seats which are heated and electric
Does anyone have a wiring diagram so i work out if these new ones are heated aswell? They are definitely not electric lumbar or have airbags but i am unsure on the heating side of things
My Build
JoeDarKa
-Given: 57
-Receive: 74
Re: New seats
Reply #11 on:
October 01, 2012, 04:09:06 pm »
So I've had a further look at the wiring and here are my findings...
New Seat - Drivers
3
4 - Black blue thin
5 - Brown thick
6
7
8
9
10 - Purple blue thick
New Seat - Passengers
1 - White thin
2 - Blue white thin
3 - Red yellow thick
4 - Purple blue thin
5 - Brown thick
6
7
8
9
Old Seat - Drivers
3
4 - Black blue thin
5 - Brown thick
6
7
8 - Red black thick
9
Old Seat - Passengers
1 - White thin
2 - Blue white thin
5 - Brown thick
6
7
8 - Red black thick
9
With my old seats I also have the airbag and a smaller plug with a brown thin / purple thin wire in on each side.
So does anyone know what the red black thick wire is in 8?
What does the smaller plug do on my current seat?
My Build
danfalcon
Always Involved
-Given: 1
-Receive: 8
My Ride:
Re: New seats
Reply #12 on:
October 03, 2012, 07:42:03 am »
the smaller plug is for the seatbelt warning light mate
JoeDarKa
-Given: 57
-Receive: 74
Re: New seats
Reply #13 on:
October 03, 2012, 09:48:46 pm »
^^^ cheers, can just code that out as my new seats dont have it
My Build
JoeDarKa
-Given: 57
-Receive: 74
Re: New seats
Reply #14 on:
October 10, 2012, 08:52:56 pm »
So i got my new underseat plug and airbag resistors. Does anyone know the part numbers for the metal connector pieces that sit inside the actual seat plug as in the above pictures? I thought the new plug would have them in but it didnt!
My Build
All Things Mk5
New seats
