Author Topic: yet another random but annoying running problem - VagCom faults added  (Read 10249 times)
Offline jedi-knight83
  • -Receive: 41
So... this has happened a handful of times now and its getting a bit annoying and puzzling.
Coming to the end of a 70-80 min drive on which i didnt drive all that hard (most of it motorway at 80ish on cruise), coming my usual route into cambs there is a little bit of road i normally blast. The car feels very hesitant and there is more intake noise than normal and the DSG gear changes make a much louder pop through the exhaust than usual... almost to the point where it sounds violent.
Got to my drive and revved the car a few times and it sounds a bit like the exhaust is blowing and also its popping away like a backfire.
its done this a few times now as i often make the same journey and it does it in the same place with the same results.
Then the next morning the car feels fine again!? It only seems to give the issue after a long drive.
Some facts....
Ive had the exhaust checked on a ramp and couldnt find anywhere it was blowing (although ive just received new clamps for it so we are going to slacken it all off and move the pipes a bit and re clamp them just to double check everything)
It failed the mot on lambda readings (yet to go back and have it re tested to get the actual readings printed out and see what readings its giving when nice and hot)
I always get pretty crap MPG even when driving sensibly.
Ive got an R-Tech stage1 map, stock air intake, milltek cat back with pre cat delete in oem downpipe, recently changed DV, PCV, cam follower, air intake assembly, n75
Any ideas anyone?
« Last Edit: September 25, 2012, 07:27:55 pm by jedi-knight83 »
Offline Ashley g
    • Durward's Autoshop
Re: yet another random but annoying running problem
« Reply #1 on: September 23, 2012, 08:26:54 am »
Faulty lambda sensor?
2007 Edition 30, build number 30 - APR Stealth TBE - APR HPFP- APR stage 2 remap - Custom CAI - KW Clubsports - 10mm spacers on rear - VW Motorsport LSD, clutch & quick shift - A few poly bushes here and there!
*SOLD AND I MISS IT!! ANYONE SELLING A NICE ED30 PM ME* - UPDATE - I HAVE IT BACK!!!
  • -Receive: 41
« Reply #2 on: September 25, 2012, 10:01:56 am »
Thanks... could that really affect the running?
Anyone else?
Offline Timi8888
« Reply #3 on: September 25, 2012, 10:33:36 am »
Yes this could affect the running of the car as it adjusts the air-to-fuel ratio
Sig to big.
  • -Receive: 41
« Reply #4 on: September 25, 2012, 05:54:08 pm »
ive got the use of vagcom for tonight...
is there anything i can log to help give a better understanding of whats going on?
  • -Receive: 41
« Reply #5 on: September 25, 2012, 07:26:03 pm »
quite a few faults stored under the "Engine" section
Quote
Tuesday,25,September,2012,19:13:40:27734
VCDS Version: Release 11.11.4
                Address 01: Engine       Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 1K0 907 115 A    HW: 1K0 907 115 A
  Component and/or Version: 2.0l R4/4V TFSI G00 0070
           Software Coding: 040300031C070160
            Work Shop Code: WSC 00655 210 91805
                      VCID: 244DF214E7B7A93865D
5 Faults Found:
001089 - EVAP Emission Control Sys
               P0441 - 001 - Incorrect Flow - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 2
                    Mileage: 104970 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:50:06
             Freeze Frame:
                    RPM: 838 /min
                    Load: 19.2 %
                    Speed: 0.0 km/h
                    Temperature: 82.0°C
                    Temperature: 42.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.716 V
008567 - Bank 1; System Too Lean off Idle
               P2177 - 001 -
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 7
                    Mileage: 105202 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:56:23
             Freeze Frame:
                    RPM: 2881 /min
                    Load: 23.1 %
                    Speed: 115.0 km/h
                    Temperature: 78.0°C
                    Temperature: 14.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.351 V
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 008 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 105493 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:35:10
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 28.0°C
                    Temperature: 30.0°C
                    Voltage: 11.684 V
012600 - Intake Manifold Runner Control
               P3138 - 008 - Regulation Deviation
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 0
                    Fault Frequency: 2
                    Mileage: 105902 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:25:30
             Freeze Frame:
                    RPM: 1643 /min
                    Load: 9.4 %
                    Speed: 56.0 km/h
                    Temperature: 67.0°C
                    Temperature: 17.0°C
                    Voltage: 14.224 V
008200 - Intake Manifold Flap; Bank 1
               P2008 - 001 - Electrical Malfunction
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 2
                    Mileage: 105902 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:25:30
             Freeze Frame:
                    RPM: 1643 /min
                    Load: 9.8 %
                    Speed: 56.0 km/h
                    Temperature: 67.0°C
                    Temperature: 17.0°C
                    Voltage: 14.224 V
Readiness: 0000 0000
Offline doylebros
  • -Receive: 310
Re: yet another random but annoying running problem - VagCom faults added
« Reply #6 on: September 25, 2012, 08:49:30 pm »
Look at the intake manifold codes via vcds web site see special notes section!
 :driver:
Offline bacillus
  • -Receive: 453
« Reply #7 on: September 25, 2012, 10:47:16 pm »
You checked the hoses at the charcoal cannister for breakage/leaks?
  • -Receive: 41
« Reply #8 on: September 25, 2012, 10:59:22 pm »
 :driver:
Thanks.
performed the basic reset and been for a drive and the fault came back again so obv something more mechanical.
  • -Receive: 41
« Reply #9 on: September 25, 2012, 10:59:48 pm »
not yet, I'll check in the morning when its light.
  • -Receive: 41
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #11 on: September 26, 2012, 12:09:38 am »
I had a problem very much the same,
vcds : engine, output test
intake manifold test it see if it moving in the engine bay, you should hear a clicking noise with a bit of a buzz
then basic settings test code 142 see if its reading error hit on the 3rd box along should go from 10 up to 50?
try that see what happens as a test, then we could narrow it down...
I'm no expert but i have been threw a few problems myself
Silver is the way !
  • -Receive: 41
« Reply #12 on: September 26, 2012, 12:14:28 am »
i did the basic settings on block 142 and it completed the adjustment fine.
took it for a drive and the fault was back.
Offline bacillus
  • -Receive: 453
  • -Receive: 41
