Author Topic: VCDS Readiness Fails - Exhaust Emissions,Catalyst System & O2 Sensors, Stage 2  (Read 4794 times)
Offline Rav2011
Hi Guys I'm in need of some advice please.
I have a mk5 GTi that is remapped to stage 2 (AMD remap) the car has a full s/steel exhaust system with a 200 cell sports cat (new BCS). The exhaust is
sealed and there are definitely no exhaust leaks in the exhaust system.
The car periodically fails on it's readiness, why I do not know? There are no DTC's showing up either which only adds to the mystery. The readiness
appears to fail every 100 miles or so from what I can tell. The car certainly seems to be restored to it's full power everytime I reset the readiness but run's
slugish when not.
It is always the same readiness tests that fail - Exhaust Emissions,Catalyst System & O2 Sensors.
At first I was told by my tuner (AMD Technik) that it was because I had a 100 cell sports cat - which I ditched for the 200 cell cat.
The lambda sensors and MAF have been changed on the car.
Has anyone else had this problem? Any ideas as to what my be going on????
Should I be taking the car back to AMD Woking and have them investigate the stage 2 map?
Offline steevo134
hi there iam also  having a similar scenario happening with my mk5 gti i have had it mapped but since then have had a full stainless added with a 100 cell sports cat i now have the engine management light oin in the dash my mate has read the code from it sayin p0010 reset it a few time one day it will do 40 miles or so then come back on other days it will hardly do 1 mile  i too am wondering if i need my tuner to further investigate incase my map is now needing a few tweaks done to it
steevo
Offline Rav2011
Your problem may just be to do with the second lambda sensor which probably needs spacing out.
Rav... what map do you have? REVO?
Offline Rav2011
No AMD map as I was already on stage 1 with them it seem like the only viable option.
Did AMD woking do the map? If so how, because to my knowledge they dont have a rolling road...
Offline Rav2011
In the Workshop, no rollers
So how did they map it... on the road?
Offline Rav2011
Off the road in the workshop, without the use of rollers.
The car was stationary mate.
That is not good mate....  :scared:
Offline Rav2011
How do I get it tuned from safely?
Take it to R-Tech or REVO. Stage 2 should not be put on the car without doing some extensive logging either on the road or on a dyno.
Offline Rav2011
Are RTech on par with Revo maps? How much for a stage 2?
Yeah Nick at R-Tech knows these engines inside out. Rtech will probably be about 350ish... REVO will be nearer 600. (I would go and see nick at R-tech and get a custom stage 2 map)
Offline Rav2011
Thanks I'll give Nick a call and see what be can do.
